![]() | Home > Technical > Spongy rear brakes after caliper cleaning, advice please |
tanloverluke Member Since: 19 Mar 2013 Location: Honiton Posts: 917 ![]() ![]() ![]() |
So, I'm in the process of cleaning my rear calipers. Unfortunately I had to take the car out today, unplanned, so had to remount everything. It was my plan to wait until the new pads arrived.
Thanks for that Ady! It does sound like I'm compressing air and that the sound is coming from the rear. I have some Castrol DOT 4 fluid so I'll perform the bleed tomorrow.
Danny.H Member Since: 25 Aug 2014 Location: Brechin, Angus Posts: 91 ![]() ![]() ![]() |
I changed my rear pads the other week, I put a piece of clear plastic tube on the nipple, opened it up and got my boy to pump the peddle, once I could see a bubble free stream through the tubing and allowing sufficient time to pass the full pipework, I closed in the nipple whilst he was still pumping the peddle, I done both rears, never touched the fronts, topped up reservoir, nice tight feel to the pedal now, no spongeyness at all. I'm not saying you shouldn't do the fronts, I just felt the brakes were good with out having too. 2007 RRS 2.7 HSE - Java Black |
Thanks Danny! Good point about doing rears only. I may anyway get a full drain and replacement at next service.
You'll know when the peddle is on the down stroke with the flow, I just watched it and when the flow sped up i tightened the nipple. 2007 RRS 2.7 HSE - Java Black |
Barryp Member Since: 05 Nov 2011 Location: Sydney Posts: 261 ![]() ![]() ![]() |
Why not buy a brake bleeder from your local car accessories shop. The one I am thinking of is called a one person brake bleeder and it has a weighted tube with a ball valve in the bottom to stop the system from drawing old fluid or air back into the system. They are very cheap and good to use when doing a full system flush. (LR recommends doing a full flush every 3 years)
Barry, I'll be doing that on Monday!
