![]() | Home > Wheels & Tyres > 22 inch wheels for snow |
Andyjay123 Member Since: 22 Aug 2014 Location: London Posts: 698 ![]() |
Ive just had some 22 inch wheels on my RRS
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9053 ![]() ![]() ![]() |
If you fit winter tyres they'll be fine. Rubber band summer slicks on the other hand? Yikes! 2012 SDV6 - it's missing a couple of cylinders
Why wouldn't normally tyres be fine? We have 4 wheel drive? |
Nik Member Since: 19 Nov 2010 Location: Up North Posts: 657 ![]() ![]() ![]() |
Your car also weighs around 2.5T and once it starts sliding, four wheel drive probably won't save you. 2015 Golf R DSG
Physics still applies to 4x4s |
I've driven for 25 years and have never once gone into a kerb AND I live in London.
Andi Member Since: 26 Jan 2014 Location: Here & There Posts: 263 ![]() ![]() |
Well, stick with what you have then! |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2796 ![]() ![]() |
First experience in snow in my RRS - straight lines not a problem - corners was squeaky bum time - slid everywhere - 22's & Toyo tyres - agree with most of the above |
1. Winter tyres are not just for snow. They perform better in all cold conditions - even just cold wet roads. 2. If you live in London then you probably benefit from the heat island effect more than most so don't see such low temperatures as often as others. 3. If you live in London you probably benefit from gritting more than most. 4. If you live in London you probably have better access to public transport as an alternative in bad weather. 5. If you're happy with your tyre choice, then fine. Advice was sought by someone and given by others. We don't promise not to say "told you so" if you ever come on here and say "I damaged a rim sliding on snow" ![]() 2008 TDV8 - it was a labour of love and is much missed |
Peterlondon Member Since: 14 May 2014 Location: Bucks J5 M40 Posts: 80 ![]() ![]() ![]() |
So last winter on my MY10 TDV8 I had winter tyres on 20" rims.
