Home > Technical > Leaking coolant - was "RRS SC intercooler"
frostmotorsport
New Zealand 2006 Range Rover Sport Supercharged Rimini Red
I can't seem to find a lot of info about the Supercharger's intercooler, other than I believe it's the thin "radiator" down under the main engine coolant radiator? Does this share fluid with the main cooling system? Assuming, that is, that the IC is water-to-air....
I ask as the Mrs noticed a small pool of red "oil" under where the RRS is parked in the garage and on investigation it appears to be oily water, rather than oil - so I assume it is engine coolant. I note there is a small amount on the front of the underside of the car in the middle - so under these radiators.
This appeared the other night and the car has been driven and parked several times since then with no further "leaks" - so I'm wondering if it's a) main coolant or IC coolant and b) if it was a one-off overflow situation or I have an actual leak - i.e. where does the radiator overflow pipe exit the vehicle?
Cheers. Every home should have one!
'06 RRS SC Rimini Red
'04 Audi S4 Avant
Escort Mk II Sport
Post #437373 Mon Sep 22 2014 1:19am
CRACKA
Australia 2006 Range Rover Sport Supercharged Bonatti Grey
Just saw your post. How did you go with finding out what it was??
I also have RRS S/C across the ditch. I will await your reply before going any further.
Post #440350 Fri Oct 24 2014 4:01pm
ian-r
As far as I know the intercooler is air cooled, not water. I haven't ever known an inter cooler to be cooled by water - water will be around 98-100 degrees, the whole idea is getting cold air across it to drop the internal temperature.
Sounds like a coolant leant somewhere, when I changed the condenser on mine i did notice a build up of dirt / leaves on the radiator which could have corroded it over time. Time for a strip down im afraid, happy to help if your near Nottingham?
Post #440461 Sat Oct 25 2014 11:05pm
The Supercharged engine uses a pair of air-to-liquid intercoolers sat on top of the engine, either side of the supercharger. The coolant is cooled by a radiator in front of the main engine coolant radiator. 2012 SDV6 - it's missing a couple of cylinders
Post #440474 Sun Oct 26 2014 9:12am
frostmotorsport
Thanks RRSTDV8 - I suspected that the RRS used a air-water IC.
Turns out this appears to be a engine coolant overflow - as a few days later I got the "low coolant" chime. Topped it off with 100ml of water and was fine.
There has been no evidence of any further overflow/leaks so I'll assume (for now!) it was a one off....
<nervous>
'04 Audi S4 Avant
Escort Mk II Sport
Post #440552 Sun Oct 26 2014 11:27pm
frostmotorsport
So, another 2 (small) puddles of orange coolant on the garage floor and a "low coolant" warning on the dash.... Hmmm.
I see from looking around here that the reservoir float can go porous, but does anyone know if the tanks themselves crack and leak?
Oddly it's been weeks since it last did it, I've not been on any trips or run it hard so it seems to be random...
Thoughts anyone? Every home should have one!
'04 Audi S4 Avant
Escort Mk II Sport
Post #442045 Sun Nov 09 2014 8:31pm
USAFBuckeye
United States 2007 Range Rover Sport Supercharged Stornoway Grey
What ever happened with this? I'm having similar issues and can't seem to track down the leak. It's not from a hose or another obvious source. I suspect the radiator but can't get my eyes on it. '12 RRS SC
'07 RRS SC
'11 Honda Odyssey Touring Elite (sigh...)
Gone, but not forgotten
'02 RR
'05 LR3 SE7 (Best off-road rig I've ever had) let her go @ 100K miles
Post #458953 Sun Apr 12 2015 5:01pm
USAFBuckeye
'07 RRS SC
'02 RR
Post #458954 Sun Apr 12 2015 5:02pm
frostmotorsport
I haven't had a chance to do a pressure test yet - busy trying to work and make a dollar sadly - I will get around to it at some stage soon. I still suspect my overflow bottle, as I've seen threads where they can leak.
If mine was a diesel I'd also be looking at the EGRs - they apparently can leak into the exhaust without evidence showing Every home should have one!
'04 Audi S4 Avant
Escort Mk II Sport
Post #458995 Mon Apr 13 2015 2:59am
nrosenbe
United States 2006 Range Rover Sport Supercharged Vesuvius Orange
Did you ever solve this ?
I have a similar issue
Post #505710 Sat Sep 17 2016 10:26pm
USAFBuckeye
Turned out to be a bad supercharger inter-cooler for me. '12 RRS SC
'07 RRS SC
'02 RR
Post #505723 Sun Sep 18 2016 6:17am
nrosenbe
Thanks, how did you diagnose it ?
Do you mean this part ,
1) http://landroverparts.checkeredflag.com/p/...28229.html
Or this part
2) http://landroverparts.checkeredflag.com/p/...09007.html
If its the second i cannot see any leaks on it, if its the first i assume the leak is internal
Post #505772 Sun Sep 18 2016 4:54pm
USAFBuckeye
Yes it was the aux radiator. It had a small leak at the bottom of the core. Easy to replace just hard to get to. '12 RRS SC
'07 RRS SC
'02 RR
Post #505782 Sun Sep 18 2016 6:56pm
