Home > General > C1B00 STEERING ANGLE FAULT CODE
m40cca
United Kingdom 2006 Range Rover Sport TDV6 HSE Rimini Red
hi boys had car plugged in today and its come back with C1B00 steering angle sensor ABS
Anyone had this before or know where its located thanks
Post #437058 Fri Sep 19 2014 12:20pm
It's at the base of the steering column just above the pivot that allows the steering rake to be adjusted. It's item 2 on this image.
http://www.rrsport.co.uk/gallery/albums/us...column.pdf
If you have manual steering reach/rake adjustment then item 3 is your column. If electrical adjustment then item 4 is yours. Same location for the sensor in each case.
If this is related to your other HDC fault then that might suggest that there is a sensor fault somewhere - could be ABS or the steering sensor (although that can use a default setting if necessary). Obviously, an ABS sensor failure will impact on HDC (because they are the same system essentially). 2012 SDV6 - it's missing a couple of cylinders
Post #437095 Fri Sep 19 2014 5:36pm
m40cca
It is to do with my hdc fault that's the only code that was logged on the car, the hdc fault only comes on, when I'm driving on the mway it never comes on round town and the streets only after about 25miles of continious driving
Post #437101 Fri Sep 19 2014 5:58pm
Jimmy Salsa
Australia
Just had the same issue with my RRS 2007 TDV6.
Anyone know if it is a definite replacement or is there a reset option.
Have had the fault reset with the Autologic and sensor alignment via the same and problem keeps recurring. 'Black Betty' Java Black RRS 07 TDV6
Post #439214 Sun Oct 12 2014 11:17pm
Disco_Mikey
Try a reset first. Takes a few minutes to.do Thumbs Up
Post #439218 Mon Oct 13 2014 4:45am
