Home > In Car Electronics > What is this behind my grill?
Nsp1
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
Hi all,
I was trying (unsuccessfully) to remove my front grill to get to my horn to change it as its broke and I noticed a connector. It's right in the middle behind the dash.
Can anyone tell me what it is. Should it be connected to something and what if it gets wet?
Also any advice to remove the grill to get to my horn would be very much appreciated.
Thanks in advance.
I've tried to upload a picture but it doesn't seem to be working. Sorry.
Post #437061 Fri Sep 19 2014 1:04pm
SRE
Spain
Simple, release the clips on the bonnet slam panel, then tug hard and sharp at each of the bottom corners. Best place a piece of cloth on top the bumper first, just in case you slip and scratch the paint.
It may be worth your while trying the search function on here Whistle Whistle Whistle In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #437062 Fri Sep 19 2014 1:24pm
Nsp1
I was pulling quite well but wasn't sure if it was bolted in somewhere.
Thanks, I'll give it a go later on.
I'll take a closer look at that connector too.
Post #437069 Fri Sep 19 2014 2:36pm
SRE
Spain
Post #437070 Fri Sep 19 2014 2:39pm
Nsp1
wo, thats a fair old yank!
I'd be scared of breaking it.
Got the picture uploaded now...
[URL=]
[/URL]
Post #437071 Fri Sep 19 2014 2:55pm
Nsp1
Even got my avatar uploaded too!
Check me out
Bonatti Grey
Post #437075 Fri Sep 19 2014 3:11pm
Nsp1
Bit of digging tells me it's the connector for the adaptive cruise control.
Does this mean I can just plug a unit in and it'll work?
I have normal cruise control only at the moment.
Post #437784 Thu Sep 25 2014 1:19pm
rigsby
When I had my old TDV8 it had the same connector I was told it was unused in the British market and some cars had it and some didn't. You will find it has a 12v supply to it if you ever need one Thumbs Up MY16 AUTOBIOGRAPHY Indus silver with some toys
2012 3.0 SDV6 Luxury gone, but a great motor
Post #437841 Thu Sep 25 2014 7:06pm
L4FLIROP
United States 2009 Range Rover Sport Supercharged Java Black
I have my doubts that is the cruise control the shape is wrong.
Post #447824 Thu Jan 08 2015 3:02pm
It might be a connector for the smog detector fitted in the Japanese market vehicles. 2012 SDV6 - it's missing a couple of cylinders
Post #447825 Thu Jan 08 2015 3:16pm
Maxarn58
Sweden 2006 Range Rover Sport TDV6 HST Java Black
Guys.
It IS a connector for a pollution detector, that is mounted
on Japanese cars.
You c a n use it for other things, one of the wires is "live"
when you put ignition on, and will go to sleep when car
goes to sleep.
I was thinking of using it for DRL:s
Rgds
Uffe As a rule, I always resist temptations,
unless they are irresistible.
My Ride: 2006 RRS HSE TVD6 Java Black/Cherry Woods with HST factoryfitted pack.
Post #447896 Fri Jan 09 2015 8:24am
Disco_Mikey
It is for a pollution sensor, fitted to Jap market cars. I used it for my DRLs.
Goes live when the car is "awake" after being unlocked, and switches off after approx 150 seconds once locked
Stays live all the time between these times
Post #447924 Fri Jan 09 2015 12:37pm
Nsp1
Well I have to ask, what does a pollution sensor do and why don't we have them?
Post #447963 Fri Jan 09 2015 5:18pm
Disco_Mikey
It monitors the pollution levels outside of the car... Whistle
...and if it gets too bad, it automatically turns the heaters to re-circ, rather than drawing in air from outside. Only fitted to Japanese cars, as they have high smog levels in their cities Thumbs Up
Post #447968 Fri Jan 09 2015 5:54pm
