Home > General > Hdc fault help!!!
m40cca
United Kingdom 2006 Range Rover Sport TDV6 HSE Rimini Red
Just been driving round Leeds City centre today so no more than 30mph and the dash as lit up like a Christmas tree. I fitted a brand new rear brake switch yesterday
This Censored car is doing my head in now
Box of matches and a petrol can if it carries on!!
Think it's time to go back to BMW
Post #436834 Wed Sep 17 2014 2:32pm
It would be worth checking the battery too. Low voltage from a tired battery and/or alternator can also throw up multiple errors. 2012 SDV6 - it's missing a couple of cylinders
Post #436855 Wed Sep 17 2014 4:28pm
simple1
Or dodgy brake light bulbs......but a failing alternator will give the same symptoms 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #436871 Wed Sep 17 2014 6:58pm
m40cca
I changed the battery last month, I'll check the back light bulbs tomorrow but they are only a month or so old is there a test I can do for the alternator?
Post #436908 Wed Sep 17 2014 9:32pm
What battery did you fit?
You need to monitor the voltage to test the alternator. A good battery would have 12-12.5V without the engine running. On starting, the voltage goes up to about 13-13.5V initially and then to 14.5V+ whilst charging. This happens fairly quickly after starting.
Do you do short runs or is the vehicle started and then given a good run each time? Lots of short runs can cause the battery to weaken because it's never properly charged - especially if electrical stuff is used a lot e.g. heated seats. Leaving it "awake" but without the engine running will also do for the battery. A corroded rear glass hatch switch can also lead to battery drain whilst parked.
Be worth checking the earth points too on an older vehicle. 2012 SDV6 - it's missing a couple of cylinders
Post #436914 Wed Sep 17 2014 11:29pm
m40cca
I do a mixture of long and short journeys, I did change the rear switch when I took it out for colour coding as it was really rusty
I'll get the alternator and earth points checked today thanks for your advice
Post #436923 Thu Sep 18 2014 7:46am
mnk
Did this problem get solved?
Post #458670 Thu Apr 09 2015 10:34am
