![]() | Home > General > Hdc fault help!!! |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9024 ![]() ![]() ![]() |
It would be worth checking the battery too. Low voltage from a tired battery and/or alternator can also throw up multiple errors. 2012 SDV6 - it's missing a couple of cylinders
Or dodgy brake light bulbs......but a failing alternator will give the same symptoms 2x TDV6. SE and HSE. Both returned to sender with issues👀
m40cca Member Since: 04 Sep 2014 Location: leeds Posts: 89 ![]() ![]() ![]() |
I changed the battery last month, I'll check the back light bulbs tomorrow but they are only a month or so old is there a test I can do for the alternator? |
What battery did you fit?
I do a mixture of long and short journeys, I did change the rear switch when I took it out for colour coding as it was really rusty
mnk Member Since: 25 Nov 2013 Location: United Kingdom Posts: 231 ![]() ![]() |
Did this problem get solved? |
