![]() | Home > In Car Electronics > GVIF, Iphone Mirroring and Reverse Camera |
Danny.H Member Since: 25 Aug 2014 Location: Brechin, Angus Posts: 91 ![]() ![]() ![]() |
Just so I get it right in my head, please let me know if you spot an obvious mistake.
Is this suitable flydive?
I think I've got that, but I don't want to power the reverse light when I use the switch to power the camera but still have the luxury of the camera turning on when I select reverse, looking at my drawing above do I have the diode in the right place? you may need to select it in my gallery to get a clearer view of it.
flydive Member Since: 16 May 2007 Location: South Posts: 1213 ![]() ![]() ![]() |
Sorry for the late reply.
broncoupe Member Since: 24 Jul 2011 Location: dorset Posts: 61 ![]() ![]() |
Stop making your life complicated use. KIS ---keep it simple
Well, that is your choice.
Cheers guys |
Do you not read posts what I suggested gives BOTH
How? '08 RRS TDV8
I've done this I think but it doesnt seem to work, camera powered to socket but doesn't switch on, when I introduce the grey wire (switch wire) the camera displays a picture on screen straight away (expected) but when the power is removed from the grey wire I get no picture, I can switch through the channels after I remove the grey wire but nothing , now if I plug the camera into one of the other AV sockets I get a picture without the grey switch wire no problem, if I then introduce the grey wire again it auto switches as I'd expect but too the designated rear camera source AV socket which the cam is no longer on. Do I need to jumper the designated camera AV socket to an AV socket to allow the above. Please be patient I am a total novice and believe it or not I have read a tonne ove theads on it, I would get it pro fitted but I've been waiting to get my blackvue fitted for two weeks now and I'm still waiting. 2007 RRS 2.7 HSE - Java Black |
It is working correctly.
So how can I view the rear camera without being in reverse? Like when driving along, I thought that's what everyone was doing! 2007 RRS 2.7 HSE - Java Black |
You have 2 ways of doing it, well 3 actually.
Aye option two looks more desirable, I have just purchased one of these
