Home > In Car Electronics > GVIF, Iphone Mirroring and Reverse Camera
Page 1 of 3 123>
Danny.H
Scotland 2007 Range Rover Sport TDV6 HSE Java Black
I've just purchased a GVIF and was wondering if anyone has successfully used it to screen mirror their iphone to their nav system?
This is the unit I've bought
http://www.hids4u.co.uk/Land-Rover-Discove...creen.html
I'm thinking of picking up one of these and fitting it through the AV connections on the GVIF
http://www.viking-direct.co.uk/catalog/cat...oC49jw_wcB
Am I barking up the wrong tree here, will this just send a audio video link from my phone I.e playing a movie file and not actually mirror my actual phone screen?
Any chaps tried this before? 2007 RRS 2.7 HSE - Java Black
Post #435731 Mon Sep 08 2014 10:19pm
PEACHY
Very Happy that's the one I purchased from Apple - it played certain videos from YouTube & I did pick up Itv & BBC player when I had a decent signal Thumbs Up it's not a lot to pay too add another mod to the GVIF but if I'm honest I never used it very much - but it does mirror your iPhone - or iPad Very Happy 16MY Estoril Blue SVR.............
Post #435771 Tue Sep 09 2014 11:15am
Danny.H
Cheers Peachy just what I wanted to hear. I've been looking at the TV units which I might do at some point in time, I'd like to get the headrest screens fitted first. Does anyone do bluray headrests? All I seem to find are dvd and all my disc collection are bluray! 2007 RRS 2.7 HSE - Java Black
Post #435793 Tue Sep 09 2014 4:02pm
Danny.H
Reverse camera
I am a bit confused by my reversing camera I got from HIDS4U, I have read I think every thread I can find on the subject including the 15 page one on the disco forum but I'm still lost, I understand I run the video cable from the GVIF unit to the camera but as you see on the pic I also have a red plug, I'm fairly certain its for power but there was only a yellow video cable supplied in the box! Am I to cut this plug off to expose the wires so I can connect it to my reversing light? Am I short a cable that has a plug to loose wires?
I have the 7.2 version of the GVIF
Post #436226 Sat Sep 13 2014 7:02pm
broncoupe
Red is power lead
Post #436306 Sun Sep 14 2014 9:36am
broncoupe
Don't cut the lead off
Hids will supply missing part I fit these and deal with them good people
The red plug will fit under the plastic trim
Camera is a tight fit needs a good push
Let me know if you need help
Post #436308 Sun Sep 14 2014 9:38am
Danny.H
Cheers broncoupe, I done a bit more fishing online last night and I see other cams come with the cable I need so maybe it was just missing, I'll give the HIDS4U people a shout.
Out of interest mate how are you running the cabling in the sport, the only option I've seen is to tape it down the sealing edge of the split tail gate screen! 2007 RRS 2.7 HSE - Java Black
Post #436332 Sun Sep 14 2014 12:45pm
broncoupe
Cable does run along original in that metal tube wipe the painted surface with cleaner so grease free warm up some insulating
Tape and cover cable
Another alternative is you can get some small clips with adesive bases to hold the wire from maplins
Cable goes through original grommets and the 2 options down to rear near side quarter then forward or you can run the video cable through head lining forward
Post #436375 Sun Sep 14 2014 6:07pm
Danny.H
Cheers mate.
Another question if you don't mind, I assume if I want to be able to switch on the reverse camera when not in reverse I also have to run the grey power cable from the GVIF and tie in to the rear also? 2007 RRS 2.7 HSE - Java Black
Post #436378 Sun Sep 14 2014 6:21pm
broncoupe
If I remember right they trigger off the grey wire don't do the can connections
If you want the option of a picture at anytime the camera will need to be ignition live
You can get that from the power socket wiring on the nearside panel
The unit comes with a neat small switch to switch picture source
Post #436400 Sun Sep 14 2014 7:18pm
Danny.H
Cheers again Thumbs Up I can run that cable to the ciggy lighter socket at the front or centre consule. 2007 RRS 2.7 HSE - Java Black
Post #436406 Sun Sep 14 2014 7:25pm
broncoupe
Any convienant ignition Supply
Post #436414 Sun Sep 14 2014 8:16pm
broncoupe
Forgot to say this is really important for everyone
I understand buying good value for money cameras for example but one area they skimp on is the quality of the cable
I'm not saying dont t buy value for money but be VERY aware of not pulling to hard on the cable while fitting
Seen several examples of the cable innerspring separating or the shielding failing and giving interference
So keep calm do not tug the cable
When going through the gromit use a piece of thin plastic tube to help thread plus provide strain relief on cable
I use beer line
Post #436415 Sun Sep 14 2014 8:22pm
flydive
Danny.H wrote:
Cheers mate.
Here is my set-up to be able to switch the camera on when not in reverse
 '08 RRS TDV8
Post #436425 Sun Sep 14 2014 8:53pm
Danny.H
So your grey wire is the one going right - to ignition. The one going left is your video, is the diode part of the car wiring? 2007 RRS 2.7 HSE - Java Black
Post #436427 Sun Sep 14 2014 8:59pm
Page 1 of 3 123>
