Home > Maintenance & Modifications > painting my Brembos and drums
tanloverluke
so, needing to refresh the look of my Brembos, and prevent the drums of my new Brembo discs from going (even more) rusty, I've embarked upon a new project. This is what they looked like earlier today:
These needed a good clean and de-greasing, so I started with WD40 to loosen the rust, then a combo of white spirit, a cloth, a green scourer and wire wool. In total I cleaned the calipers and drums three times. I took out the brake pads before the cleaning process. I also went over the areas to be sprayed with a 600 wet and dry paper.
Post clean:
I blanked off those areas that I don't want sprayed with tape and newspaper.
I've always wanted the matt black look for my calipers, so I went with a heat resistant spray from Hammerite, the "High Heat Paint" aerosol. This doesn't need a primer. I waited for everything to dry and sprayed a light layer, which I'm currently letting dry before adding to it.
After the first layer:
I haven't got a clue how this will end up, both in terms of final colour and durability, but time will tell. I'll post more photos when the last layer is on, the new stickers are on, and the wheel is back in place. Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
DONE: Meduza front bumper, AB rear bumper, AB tailpipes, calipers repainted, rear upper tailgate upgrade, side steps, AB front grille, AB side vents, rear LED lights, clear side repeaters, integrated daytime running lights, LED headlights.
TO DO: color code sills and pillars.
Post #436352 Sun Sep 14 2014 4:15pm
tanloverluke
these are the stickers that I opted for:
http://r.ebay.com/R4tAcd Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Post #436354 Sun Sep 14 2014 4:26pm
tanloverluke
ok so here is the end result with the stickers on. they're in fact better irl than on the photo:
the only thing i'm thinking of is the lacquer. I'm wondering if it will need a lacquer because apparently the finish as it is now is very hard (once cured). If I do go for a lacquer then it would have to be matt lacquer (a regular one would of course defeat the object), just to give me a finish that's probably easier to clean.
I'm gonna let the spray cure a little longer before I pop the wheel back on. I'm not using the car this week so it'll be given a weeks drying time, should be sufficient!
pics with wheel on coming... Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Post #436368 Sun Sep 14 2014 5:25pm
ABSport
United Kingdom 2011 Range Rover Sport 3.0 TDV6 Autobiography Santorini Black
Looks good but I would like to see a shiny caliper and clear gloss over the sticker would protect it. Otherwise Thumbs Up
Post #436377 Sun Sep 14 2014 6:17pm
Andyjay123
Why would you paint the drum? This isn't a criticism, I would like to know as my calipers are being sprayed red this week
Banks
Andy
Post #436379 Sun Sep 14 2014 6:25pm
SCdavies
England 2006 Range Rover Sport Supercharged Zambezi Silver
The steel drums rust very quickly if they are not coated with any protection.
Post #436381 Sun Sep 14 2014 6:29pm
tanloverluke
I agree with you there, I think a gloss would be optimal to protect everything. I'm gonna look on fleabay tomorrow for clear coat on matt paint. Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Post #436386 Sun Sep 14 2014 6:44pm
tanloverluke
Banks
Andy
Hi Andy, I've just mounted the wheel and I think the drum & caliper matt black combo looks amazing, though I'm not so sure about red being a great combo. I can't take a piccie right now as it's pitch black out, but I'll post one tomorrow morning for you to view. If I had red calipers, I would probably get the drum painted titanium silver so as to match the alloys.
Regardless, you should get the drum painted, rust is a horrid colour! Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Post #436390 Sun Sep 14 2014 6:48pm
PEACHY
TLL - cracking job mate - I would try to get a lacquered finish if poss Bow down Bow down 16MY Estoril Blue SVR.............
Post #436391 Sun Sep 14 2014 6:50pm
tanloverluke
Peachy mate I've just put the wheel back on and no kidding, it's the dogs Censored ! 3+ hours spent on one side but it's worth it! They've turned out darker than the last piccie shows, I used the entire aerosol can on this offside section.
You're right it needs the clear coat! But I don't wanna lose the matt/stealth look. and it's gotta be a spray solution, can't stand using a brush Thumbs Up Exclamation Any ideas gladly send them my way Thumbs Up Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Post #436394 Sun Sep 14 2014 6:58pm
Andyjay123
Tan
Tanluke
Ok will do
Do you have a photo of red/titanium as I can't find one on tinternet
Post #436404 Sun Sep 14 2014 7:23pm
tanloverluke
unfortunately I don't, it's just a vision/epiphany I had Razz
I know that many other forum members have painted their calipers red, maybe they can help you out. Look at this thread:
http://www.rrsport.co.uk/forum/topic21307.html Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Post #436407 Sun Sep 14 2014 7:34pm
Leeser23
United Kingdom 2007 Range Rover Sport TDV8 HSE Siberian Silver
Evening all,
I wanted to paint mine , didn't know you could get new stickers ? Can you get new brembo stickers then ?
Nick
Post #436615 Mon Sep 15 2014 10:04pm
tanloverluke
you sure can, just have a look on ebay and search for brembo stickers. lots of different sizes and colours. Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Post #436624 Mon Sep 15 2014 10:55pm
shakeapaw
ive had the stickers, plus black and red paint for over a year now, one day I will get round to it Laughing 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater Smile)))
Post #436631 Tue Sep 16 2014 4:19am
