Home > In Car Electronics > Nav TV Xbox poor quality
looneyfitter
2005 Range Rover Sport TDV6 HSE Alaska White
Has anyone fitted the Nav TV module to there touch screen? I get horizontal running lines a bit like waves. It's only slight but still there. This is on both the DVD and TV inputs. Any ideas?
Also I've connected my sons xbox 360 and the Lower 20mm of the screen is blurred and showing a Part of the Xbox home page even when playing a game.. I've a feeling it may be a resolution problem? Strange thing is it's fine when playing a DVD? Any ideas on how to get the res right when playing games?
Many thanks Smile
Post #432398 Tue Aug 05 2014 4:45pm
broncoupe
I'm a nav tv installer never had that problem
If you think it's a ground loop interference on video picture you can get a filter from any security camera firm
They do work I built a covert RR Sport for military use had a lot of video interference problems caused by so much kit in the vehicle those filters worked a treat
Post #436309 Sun Sep 14 2014 9:43am
looneyfitter
Hi mate thanks for the reply.. Don't suppose you have a link to the filter do you? Strange thing is, I tried his ps3 on it and it was fine.. I rang Nav TV and he mentioned fitting a resistor to the AV line in? Wasn't sure what he meant tho..
Regards
Post #436314 Sun Sep 14 2014 10:20am
broncoupe
What I will do is speak to Julian for you tomorrow and post a reply
What I would suggest is you need some definates to work from
1 off the best sources for audio or video of quality is an iphone or iPod for test purposes but you need the genuine
Apple lead to get a picture out
The filter is from a shop that does CCTV equipment £10.00 they suffer interference because of there long cable runs
You may end up needing a video amp
The factory screen likes a strong PAL signal
Post #436325 Sun Sep 14 2014 11:38am
looneyfitter
Hi mate great ok I'll try to pick an iphone lead up and try that too Smile
Post #436412 Sun Sep 14 2014 8:03pm
broncoupe
Spoke to Julian for you that mode was only for a particular Alpine unit no longer available
So for now you need a proven source remember once you have the iPod lead it will plug into any tv etc with a video in
Also PAL NTSC switching is in iPod menu
Post #436573 Mon Sep 15 2014 5:44pm
looneyfitter
Hi mate thanks for that.. I have all alpine av stuff plugged into it. Have ordered a lead.
Out of interest what was the mod?
Post #436609 Mon Sep 15 2014 9:25pm
broncoupe
It was connected to the vehicle dock unit that alpine did the power supply fluctuated causing the interference .
Post #436611 Mon Sep 15 2014 9:39pm
