Home > Technical > One touch window lowering not working
Sag
Hi guys,
When I press any of the window switches to lower or raise the glass, the one touch operation doesn't work. I have to keep it pressed and when I let go, the window stops moving.
Any suggestions? Would it have anything to do with the interior alarm sensor as I currently have this disconnected?
Any help appreciated Thumbs Up LCFC. Receiver of threatening letters from Overfinch.
Post #436077 Fri Sep 12 2014 9:42am
fkarim
Looks like they need resetting. Check the manual for instructions to perform a reset but I think it is done on each window by fully closing it and then holding the switch in the close position for a few seconds.
Post #436082 Fri Sep 12 2014 9:55am
PEACHY
^^^^^^ that guy is good Bow down 16MY Estoril Blue SVR.............
Post #436087 Fri Sep 12 2014 10:01am
Sag
Cheers guys, will give it a shot Thumbs Up LCFC. Receiver of threatening letters from Overfinch.
Post #436089 Fri Sep 12 2014 10:39am
fkarim
Apparently "one touch" only works on the driver's window in your model. From 2006 handbook:
One touch operation (driver’s door only)
By pressing firmly (and then releasing) the switch, a window will open or close fully at a single touch. Window movement can be stopped at any time by BRIEFLY pressing the switch again.
Resetting one touch operation
Disconnecting the power when the window is moving will cause memory loss. To reset the memory, drive the window to the top and keep the switch pressed for one second.
Post #436091 Fri Sep 12 2014 11:10am
V8SC
2006 Range Rover Sport Supercharged Bonatti Grey
Sag, one touch only on drivers door for 06MY but its as fkarim says......
Hold the switch down until window fully lowers and you hear a feint click sound. Then all the way up again until you here the click sound. One touch should then be reset Thumbs Up
It happens some time that the one touch memory gets lost for no apparent reason.
Good luck ! Carl
Post #436142 Fri Sep 12 2014 9:38pm
Sag
Thanks for all the info guys - tried numerous times with no luck Evil or Very Mad LCFC. Receiver of threatening letters from Overfinch.
Post #436196 Sat Sep 13 2014 3:13pm
W18ODY
Just done this with mine and sorted it Thumbs Up
Post #436200 Sat Sep 13 2014 4:12pm
stealth
United Kingdom 2006 Range Rover Sport TDV6 SE Arctic Frost
Yep driver only on 2006
Post #437157 Sat Sep 20 2014 10:52am
Andyjay123
FKARIM
Thanks it's worked on my 2010 model!!!
Nice one
Andy
Post #437208 Sat Sep 20 2014 7:17pm
fkarim
Post #437240 Sat Sep 20 2014 8:33pm
