![]() | Home > Technical > One touch window lowering not working |
Looks like they need resetting. Check the manual for instructions to perform a reset but I think it is done on each window by fully closing it and then holding the switch in the close position for a few seconds. |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2795 ![]() ![]() |
^^^^^^ that guy is good |
Sag Member Since: 07 Jul 2009 Location: Leicester Posts: 564 ![]() ![]() ![]() |
Cheers guys, will give it a shot |
Apparently "one touch" only works on the driver's window in your model. From 2006 handbook:
V8SC Member Since: 29 Oct 2011 Location: Hampshire Posts: 145 ![]() ![]() |
Sag, one touch only on drivers door for 06MY but its as fkarim says......
Thanks for all the info guys - tried numerous times with no luck |
W18ODY Member Since: 31 Aug 2014 Location: north east Posts: 87 ![]() ![]() |
Just done this with mine and sorted it |
stealth Member Since: 09 Jul 2014 Location: Hampshire Posts: 30 ![]() ![]() ![]() |
Yep driver only on 2006 |
Andyjay123 Member Since: 22 Aug 2014 Location: London Posts: 698 ![]() |
FKARIM
