Home > Wheels & Tyres > Run Flats on a RRS? |
RangeRoyer Member Since: 28 Jul 2014 Location: Worcestershire Posts: 21 |
I have picked up a RRS HSE 2010 model and I see that the vehicle is fitted with Pirelli P Zero run flats on the front axle with factory fitted Conti on the rear. Not sure if a standard RRS alloy rim is designed for Run Flats. Is there anything fundamentally wrong with what I have here? Thanks for any advice on this.
Mon Sep 08 2014 8:10am |
Where did you pick your motor up from? Dealer or private sale? Personally, i would change all the tyres to the same make, ie Pirelli Scorpion none runflats. I would never mix tyres on any of my vehicles. |
Mon Sep 08 2014 9:08pm |
None other than Stratstone of Mayfair. The sales person was not aware of the fact that different tyres were on the vehicle. They were different on the same axle. Hard to believe but true. I have moved the wheels so that at least they are the same on each axle. The alloys are perfect so I suspect that when the reconditioning was done the wheels were put back on without checking. |
Tue Sep 09 2014 6:29am |
No surprise there then. I would send the vehicle back and be asking for 4 nee matching tyres. 1, its not standard practice for a L/R dealer to sell a vehicle with none matching tyres. 2, should you have a warranty claim for suspension or drivetrain issues, then JLR may reject the claim due to none recommended tyres been fitted. 3, should you have an accident in the vehicle, your insurance company may also pick up on the fact that your tyres are none factory spec or recommended should your vehicle be inspected, and also reject a claim. 3 good reasons to get the dealer to change them all foc. What else have they missed on their inspection before releasing the vehicle to you? |
Tue Sep 09 2014 9:02am |
There is more: They are not sure what an Auxiliary Heater is doing on a RRS and stated that RRS is not fitted with an Auxiliary Heater. As I can see the device under the bonnet I pointed out that the vehicle certainly does come with the aux heater as its under the bonnet. They asked me to let them know more about this.
Tue Sep 09 2014 9:31am |
DavidHirst Member Since: 07 Sep 2013 Location: york Posts: 93 |
Had an X6 that needed 2 new rear tyres. Was told that you cannot mix and match run flats and standard tyres on same vehicle. MY 09TDV8 |
Tue Sep 09 2014 9:43am |
muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5637 |
Agree mixing tyres is not recommended - furthermore run flat should only be fitted if you have tpms Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Tue Sep 09 2014 11:01am |
362bkr Member Since: 06 Dec 2013 Location: devon Posts: 856 |
Yes a brilliant point Muddy . |
Tue Sep 09 2014 11:32am |
Take it straight back to s tstones and stand your ground until they sort it. MY 09TDV8 |
Tue Sep 09 2014 12:12pm |
