![]() | Home > Technical > remove side front sensor without the bumper coming off? |
designboy Member Since: 03 Feb 2014 Location: whitehead co antrim Posts: 338 ![]() ![]() ![]() |
I took the bottom driver side grille bit off the inner wheel well. It opened up enough to pop out the side of the bumper off the clips, then I slid my skinny arm into the hole by the small radiator that hides out in there. I then tried everything I could to get the sensor pushed out, it wont budge! I see from doing searches on here that there are 3 clips that hold it in, but I cant find where you press the clip to pop it out?
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2796 ![]() ![]() |
Well done - get someone to give the sensor a push inwards from the outside - ( if that makes sense - that should do the trick ) |
Thanks Peachy! Will give that a try Sunday then. It looked easy in a video I seen on a FFRR but its not the same job here on mine. I even tried to ply it out on the front of the bumper and scored a lovely big scrape in the bumper and the housing for the sensor! Agh!! |
Still the same, I'm afraid to break it. I've pushed as hard as I can on it, got the outside pressed at the same time, but nothing. It is the far corner sensor. Am I going too lightly? |
They are by nature a |
flydive Member Since: 17 May 2007 Location: South Posts: 1213 ![]() ![]() ![]() |
I suggest you take off the bumper, takes just few minute and is very easy.
Removing the front bumper |
I was told by my mate when he plugged it in to the computer that driver side was out. It says on dash front sensor in active. So I've got a spare that I hoped to just pop out and replace. She's a big wagon trying to park at school runs. Was grand over the summer but I'm back in that tight street again. |
I appreciate your frustrations - I would be lost without my parking aids - try again your way |
m3virus Member Since: 18 Sep 2013 Location: birmingham Posts: 36 ![]() ![]() ![]() |
You can get to the front corner sensors by removing just the headlights. Current 55 reg 2.7tdvs with Hst extras |
