Home > Technical > remove side front sensor without the bumper coming off?
designboy
United Kingdom 2007 Range Rover Sport TDV8 HSE Lux Stornoway Grey
any better tips on how to remove side front sensor without the bumper coming off?
I got my hands at it from behind but its stuck in good!
Post #435428 Sat Sep 06 2014 2:51pm
designboy
I took the bottom driver side grille bit off the inner wheel well. It opened up enough to pop out the side of the bumper off the clips, then I slid my skinny arm into the hole by the small radiator that hides out in there. I then tried everything I could to get the sensor pushed out, it wont budge! I see from doing searches on here that there are 3 clips that hold it in, but I cant find where you press the clip to pop it out?
Is there any smart way to do this? Was half tempted to just punch it out with a hammer!
Ive put the thing back the way I found it with my tail between my legs. I now need your help guys, totally stuck ;(
Post #435443 Sat Sep 06 2014 5:18pm
PEACHY
Well done - get someone to give the sensor a push inwards from the outside - ( if that makes sense - that should do the trick ) Thumbs Up 16MY Estoril Blue SVR.............
Post #435454 Sat Sep 06 2014 6:36pm
designboy
Thanks Peachy! Will give that a try Sunday then. It looked easy in a video I seen on a FFRR but its not the same job here on mine. I even tried to ply it out on the front of the bumper and scored a lovely big scrape in the bumper and the housing for the sensor! Agh!!
Post #435468 Sat Sep 06 2014 7:22pm
designboy
Still the same, I'm afraid to break it. I've pushed as hard as I can on it, got the outside pressed at the same time, but nothing. It is the far corner sensor. Am I going too lightly?
Post #435545 Sun Sep 07 2014 4:32pm
PEACHY
They are by nature a Censored to get off - you need to bend the tabs on the inside out of the way & push from the outside in - it can be done but it is a practised method - Whistle
Why may I ask do you want the sensor out - in my experience if 1 has failed replace all 4 - this is then easier with the bumper off Thumbs Up 16MY Estoril Blue SVR.............
Post #435546 Sun Sep 07 2014 5:09pm
flydive
I suggest you take off the bumper, takes just few minute and is very easy.
Better if 2 people but even alone is no problem
There is a video somewhere on the net
Once out you will see how to replace the sensor. '08 RRS TDV8
Post #435559 Sun Sep 07 2014 7:20pm
PEACHY
Removing the front bumper Thumbs Up
Part - 1
Part - 2 &list=PL8B8F797C102C869E
All in all 1/2 hour - be prepared to replace broken fasteners & or plastic clips Big Cry 16MY Estoril Blue SVR.............
Post #435563 Sun Sep 07 2014 8:09pm
designboy
I was told by my mate when he plugged it in to the computer that driver side was out. It says on dash front sensor in active. So I've got a spare that I hoped to just pop out and replace. She's a big wagon trying to park at school runs. Was grand over the summer but I'm back in that tight street again.
Post #435565 Sun Sep 07 2014 8:22pm
PEACHY
I appreciate your frustrations - I would be lost without my parking aids - try again your way Thumbs Up it really is a simple job to remove the bumper but if I was gonna do that I would certainly replace all 4 Wink 16MY Estoril Blue SVR.............
Post #435566 Sun Sep 07 2014 8:29pm
m3virus
United Kingdom 2005 Range Rover Sport TDV6 HSE Zambezi Silver
You can get to the front corner sensors by removing just the headlights. Current 55 reg 2.7tdvs with Hst extras
Post #436100 Fri Sep 12 2014 2:47pm
