Home > General (L494) > Wheel Spacers for 22"
RNXS
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Santorini Black
I'm looking to get wheel spacers for my 22" wheels on the Sport Autobiography.
The wheels do look a bit squished inside the wheelwell
Anybody suggest for or against?
Also anyone done this in the past or has suggestions regarding how big a spacer I should use?
Post #435232 Thu Sep 04 2014 2:09pm
DaveW
I guess it depends on how far you want to go out.
However, you must recognise that we will have optimised the wheel position and designed all of the parts that hold that in place before embarking on the validation programme to sign the whole lot off and also we would have taken scientific measurements in Road Load Data (RLD) before running rigourous test cycles to replicate those loads up to end of life.
By changing the moments of inertia, there is no telling what you may do, but at the very least, you'd have to expect an accelerated wear rate on things like wheel bearings and stress on wheel studs.
Also, depending on how far out you do go, you could actually end up seriously degrading the handling (causing unnecessary RSC interventions) and having strange tyre wear unless you get the geometry set to accommodate this.
Are those good enough reasons as to why not? Very Happy
Post #435342 Fri Sep 05 2014 3:35pm
362bkr
United Kingdom 2012 Range Rover Sport SDV6 Autobiography Santorini Black
So is that a yes or no DaveW ? .................... Rolling with laughter
Post #435359 Fri Sep 05 2014 5:46pm
DaveW
What..... was that a little too complicated for you? Rolling with laughter
Post #435364 Fri Sep 05 2014 5:58pm
AJ1
Australia
Just fitted 12mm to my 22's. Rear only, got the look I wanted. Thumbs Up MY 14.5 SE SDV6 Loire Blue. Silver roof. 22's.
Post #494535 Wed Apr 27 2016 3:16am
Johnski
In UK. Don't forget to let your insurance company know of this modification. Some can rather load you, but without notification your insurance is invalid in the event of any accident, and that would be a great shame not to be able to keep your vehicle.
The Police are notified by many that you have been driving without insurance, (in event of accident) but I'm sure you have done all this, just a reminder for others going down this route. John
Post #494536 Wed Apr 27 2016 6:34am
AJ1
Australia
Also, don't forget to tell the police if you ever speed as this is also illegal and can effect your insurance zzzzzzzzzzz. Just saying. Rolling with laughter Thumbs Up Bow down MY 14.5 SE SDV6 Loire Blue. Silver roof. 22's.
Post #494537 Wed Apr 27 2016 6:38am
philmw
United Kingdom 2012 Range Rover Sport Supercharged Sumatra Black
I believe it depends on the accident and what contributed to it. The insurers are liable for 3rd party cover, but may come after you for the money. Fully comp depends on the claim. If the wheel/hub failure was the cause of the accident, then you are foobared. If not and the car is written off they may ask you to pay the difference between the premium and what the premium would have been if the mods were declared.
One could try and argue that using spacers makes the car less attractive to thieves and so the premium you have been paying should have been less. Wink
Sorry AJ. Razz
Post #494550 Wed Apr 27 2016 12:26pm
AJ1
Australia
Just not necessary phil. MY 14.5 SE SDV6 Loire Blue. Silver roof. 22's.
Post #494620 Wed Apr 27 2016 8:48pm
MafroSVR
United States
Re: Wheel Spacers for 22"
Many have pointed out reasons to not do it, but I have heard H&R are the best. Also, you should consider an aftermarket set of wheels as they can adjust the offset to give you the look you are looking for without the added stress on said items.
Post #494685 Thu Apr 28 2016 2:46pm
DaveW
Whilst fitting the different offset wheels alone would improve the joint integrity over fitting spacers, the stresses on the adjoining components remain the same so you're no better off.
There's a reason why we have CAE and Road Load Data to set wheel positions......
Post #494725 Fri Apr 29 2016 8:00am
Andrew
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Firenze Red
Probably doesn't know why he can break a pencil holding it at the ends rather than fingers together in the middle! 5.0 Ltr Superchrged RRS2, Chile Red, Sideways out of junctions!
TDV8 HST Stornaway on a 08.. remapped.. now gone and replaced, was a mighty fine car..
4.2 SC First Edition when they first came out, quick car!
Post #494751 Fri Apr 29 2016 8:28pm
