Home > Maintenance & Modifications > Mega flush review !
jim4244
England 2013 Range Rover Sport SDV6 HSE Santorini Black
Silence....................... Shocked
Post #435197 Thu Sep 04 2014 9:42am
mad-dafty
Scotland 2010 Range Rover Sport 3.0 TDV6 Autobiography Stornoway Grey
I guess the answer is no sestorious. Mr. Green
Quote:
So, how long does it take for the gearbox (which will likely be at it's full operating temp of 80+ degrees) to cool down to 30-35 degrees? I can assure you, it is longer than 1 hour
 2010 RRS TDV6 3.0 Autobiography - Stornoway Grey
2006 RRS TDV6 2.7 HSE -Java Black
2008 BMW 3 Series 2.l
2006 BMW 5 series 2.l
Post #435199 Thu Sep 04 2014 9:49am
sestorious
England 2008 Range Rover Sport Supercharged HST Santorini Black
Looks like it !
Post #435202 Thu Sep 04 2014 10:54am
bigdavy60
2005 Range Rover Sport TDV6 HSE Java Black
well on that note i guess ill also be needing a gearbox megaflush from disco mikey the next time he manages to get down the glasgow direction lol Bow down Thumbs Up
Post #435211 Thu Sep 04 2014 11:36am
Disco_Mikey
From memory, it is around 3.5-4 hours to cool naturally. Less in the middle of winter, obviously
When the car is parked up when warm, you get a degree of 'heat soak' so the temperature actually increases by a few degrees after switching off
Post #435224 Thu Sep 04 2014 12:43pm
rich_sargie
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Bali Blue
I recently did a triple flush on my box, the gear box was at 25c when I started. And after
Each drain and refill if was run for 2-3 mins through every gear. When filling for the third
And final time the gear box temp was only 45c.
Post #435915 Wed Sep 10 2014 5:54pm
Nsp1
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
Disco_mikey,
Trying to pm you about a flush but it doesn't seem to be working.
Can you pm me and I'll try to reply to that?
Post #437777 Thu Sep 25 2014 1:08pm
mark.b
2007 Range Rover Sport TDV8 HSE Stornoway Grey
I had my tdv8,s gearbox oil flushed about 2 weeks ago by Geoff since then the car drives much quieter and gear changes are faultless so smooth so i can highly recommend it being done he comes to you too
Geoff is on here so PM him
Mark
Post #437799 Thu Sep 25 2014 2:52pm
Disco_Mikey
Disco_mikey,
Replied Thumbs Up
Post #437858 Thu Sep 25 2014 9:18pm
lrserviceandrepair
All customers now will be asked to watch the level check procedure and look at live data on Autologic Diagnostics 30-50 degrees as stated on Topix.
The thing is, i guarantee every time the level is checked afterwords you will have a slight level indifference of be it 10-100 mls due to temperature change. Even within Land Rover level check specification 30-50 degrees. The Autobox has a dry fill capacity of 9500mls of ZF6HP SPEC OIL. All this scare mongering is not required and I would be quite happy to have a chat with anyone about the work that is carried out as opposed to have my business bad mouthed on a public forum.
I started my business from a £2000 loan off my parents which I paid back and me and my father built my first workshop from the ground up on an evening and weekends whilst still working full time. I moved to a larger workshop on my own 4 years ago and I now have 3 ex-dealer technicians and 2 full time parts staff and myself. None of this has come from ripping people off, just hard work and honesty.
Most days you would think we were a dealer looking in our car park at cars waiting to be repaired and serviced. We are just a family run independent specialist. I have invested massively into the business from having nothing.
I don't post on here as often as I should and there is one simple reason for this, i am just too busy. So I miss a lot of posts about my business.
Kind Regards Richard
Post #454920 Fri Mar 06 2015 8:36pm
Lost for Words
Richard, I'm sure no-one's intention was to bad mouth your business. It is only understandable that there will be concerns about such an important procedure and with the TCM being so sensitive to temperature. Questions are only asked for the benefit of all members and I'm sure many sponsors can sympathise with how busy you are.
I wish you the best of luck with your business. Thumbs Up Visiting from DISCO3.CO.UK
Post #454953 Sat Mar 07 2015 8:29am
kevtydd
Wales 2008 Range Rover Sport TDV8 HST Java Black
Reading this I think my 08 TDv8 HST could do with a gearbox flush.Anyone know of any good independants that do it in North Wales area up to about 30-40 miles radius ?
Post #454990 Sat Mar 07 2015 1:40pm
