![]() | Home > Faults & Fixes > Yellow parking light on?? |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9013 ![]() ![]() ![]() |
Could be an EBA fault, could be brake pad wear. Need to check for any fault codes and go from there. 2012 SDV6 - it's missing a couple of cylinders
Bungleaio Member Since: 06 Apr 2014 Location: Leicester Posts: 172 ![]() ![]() |
Taking the negative cable off the battery and then reconnecting it again can sometimes reset the light and get the handbrake working again. If the light comes back again then it needs some attention. |
