Home > Maintenance & Modifications > Front diff pinion seal replacement.
RRS Daz
Has anyone had this part replaced? if so at what cost?
Also has anyone actually swapped this part themselfs? I don't mind tackling jobs myself as long I've not to drop diffs off etc as I work off the floor (old school Wink )
Sorry the car is a 57 plate tdv8 if that makes a difference.
Post #432056 Thu Jul 31 2014 7:39pm
RRS Daz
No one?
Post #432100 Fri Aug 01 2014 3:42pm
Disco_Mikey
The diff is supposed to be set up on a bench, with new collapsible washers etc.
There was a guy on D3 who replaced his. Marked the nut and retightened to the same marks. Diff died 1000 miles later
Post #432115 Fri Aug 01 2014 5:52pm
RRS Daz
Thanks for that.
Doesn't sound like a diy job then Thumbs Up
Have you done one? If so how many hours should it take?
Post #432122 Fri Aug 01 2014 7:20pm
Disco_Mikey
Never done one either Sad
Post #432132 Fri Aug 01 2014 9:30pm
RRS Daz
Ok thanks for answering.
I'll have a ring round for some prices.
Post #432183 Sat Aug 02 2014 7:17pm
adigorn
United Kingdom 2007 Range Rover Sport TDV6 HSE Cairns Blue
Which is the correct LR service procedure
I ve done a few in the past no probs so i suppose it was just incorrectly performed repair
The flange is a really tight fit ( you will need a puller of some kind)
Post #432202 Sun Aug 03 2014 7:12am
RRS Daz
We'll I've decided against doing it myself now.
How long did it take you? Cost of part/parts?
Thanks
Post #432203 Sun Aug 03 2014 7:27am
adigorn
An hour maybe ah hour and a half ( on ramp )
I was able to put my hydraulic puller on the flange
Parts wise the flange usually was ok with no grove so
the seal was the only part changed
Post #432206 Sun Aug 03 2014 7:57am
RRS Daz
That's great Thumbs Up
Thanks for the help.
Post #432233 Sun Aug 03 2014 11:08am
