Home > Maintenance & Modifications > Sluggish, black smoke ,then fine |
aljo Member Since: 13 Jun 2006 Location: West Sussex Posts: 3243 |
could maybe be a pin hole in your inter cooler pipe and obviously gets bigger when under higher pressure(accelerating) |
Thu Jul 24 2014 7:55pm |
Faulty EGR valves maybe, common problem. |
Thu Jul 24 2014 8:13pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9005 |
I'd go with EGR valves too. The delay in responding to the throttle is the EGR being slow and then the smoke is because the engine is momentarily overfuelled. That or an incipient failure of the intercooler hose. 2012 SDV6 - it's missing a couple of cylinders
Thu Jul 24 2014 10:34pm |
rich_z3 Member Since: 16 Feb 2014 Location: Runwell, essex Posts: 68 |
Thanks for the help, I had the egr valves blanked a cpl months ago , does that rule them out of the problem |
Fri Jul 25 2014 5:41pm |
Bladeboy Member Since: 17 Sep 2013 Location: Benson Posts: 522 |
I had the same thing. The EGRs were done but there was also a split in the intercooler. All fixed now and it's like a different car. |
Sun Jul 27 2014 4:53am |
Had it checked out , split on inter cooler pipe, got one coming tomorrow from stealer £45, thanks for all your help and advice.
Mon Jul 28 2014 6:40pm |
