Home > Maintenance & Modifications > Sluggish, black smoke ,then fine
rich_z3
United Kingdom 2010 Range Rover Sport TDV8 Autobiography Santorini Black
Hi guys, bit of a strange one here driving along all is fine slow down for traffic then when I accelerate its as if it don't want to change down and go , it changes down feels like its being held back for a few seconds then chucks out black smoke for a
Few seconds and then its all back to normal , I'm not getting smoke at any other time unless in this scenario , this happened 3 times to day but i was in traffic on and off most of the day so quite random, when this is happening its almost like its in limp mode for a few seconds then runs and drives as normal, I have no warning lights showing.
Thanks in advance for any advice. Rich
Post #431512 Thu Jul 24 2014 6:35pm
aljo
could maybe be a pin hole in your inter cooler pipe and obviously gets bigger when under higher pressure(accelerating)
Post #431523 Thu Jul 24 2014 7:55pm
Faulty EGR valves maybe, common problem.
Post #431524 Thu Jul 24 2014 8:13pm
I'd go with EGR valves too. The delay in responding to the throttle is the EGR being slow and then the smoke is because the engine is momentarily overfuelled. That or an incipient failure of the intercooler hose. 2012 SDV6 - it's missing a couple of cylinders
Post #431558 Thu Jul 24 2014 10:34pm
rich_z3
Thanks for the help, I had the egr valves blanked a cpl months ago , does that rule them out of the problem
Post #431625 Fri Jul 25 2014 5:41pm
Bladeboy
England 2005 Range Rover Sport TDV6 HSE Siberian Silver
I had the same thing. The EGRs were done but there was also a split in the intercooler. All fixed now and it's like a different car.
Post #431709 Sun Jul 27 2014 4:53am
rich_z3
Had it checked out , split on inter cooler pipe, got one coming tomorrow from stealer £45, thanks for all your help and advice.
Rich
Post #431815 Mon Jul 28 2014 6:40pm
