Home > Technical > 2007 range rover sport
josh_rrs
hi guys having a few issues got a warning light saying normal suspension hight only, now the car will only lift the rear and the front goes very very slowly, also it will not go into off road hight. any one els had this problem
also when the car is running u can here small puff of air every 10 seconds or so.
thanks in advance
josh
Post #431032 Sun Jul 20 2014 2:35pm
josh_rrs
update i been under the car the compressor is running (put my hand on it and felt it buzzing) coud it be a solonide problem ?
Post #431043 Sun Jul 20 2014 5:36pm
drdelrrs
Sounds like compressor on way-out unless you have leak in pipework or bellows - listen while raising and lowering (but not from under your car !!) put washing-up liquid on joints.
You could call up the 'off-road' screen in the touch display and see if the 'bars' representing 4 corners are the same or if one corner fails - could be sensors.
Post #431057 Sun Jul 20 2014 7:30pm
josh_rrs
thanks for the reply it suddenly went yesterday after not using the car for 3 days ill go check the 4x4 screen, im taking it to a rangerover dealer tomorow to have the codes read to see if they can shed sum light on the matter. i read some where i camt fit a compressor my self as it needs recalabrating and new software is this true.
thanks josh
edit sensors look ok ish the passanger rear is about 1cm lower than the other 3, now gettin a message on screen saying vehicle raising slowley as if there is not enough air in the aint tank.
Post #431063 Sun Jul 20 2014 7:46pm
josh_rrs
failed compressor !
Post #431150 Mon Jul 21 2014 12:51pm
