![]() | Home > Technical > 2007 range rover sport |
josh_rrs Member Since: 24 Apr 2014 Location: london Posts: 18 ![]() ![]() ![]() |
update i been under the car the compressor is running (put my hand on it and felt it buzzing) coud it be a solonide problem ? |
Sounds like compressor on way-out unless you have leak in pipework or bellows - listen while raising and lowering (but not from under your car !!) put washing-up liquid on joints.
thanks for the reply it suddenly went yesterday after not using the car for 3 days ill go check the 4x4 screen, im taking it to a rangerover dealer tomorow to have the codes read to see if they can shed sum light on the matter. i read some where i camt fit a compressor my self as it needs recalabrating and new software is this true.
failed compressor ! |
