![]() | Home > Technical > SMELL LEFT AFTER OPERATING AIR CONDITIONING |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1941 ![]() ![]() ![]() |
That's why in future you should always always have the AC climate control in, just adjust the temperature, never turn it off. You have some water in the system somewhere which has gone stale. I am not sure how to fix it, I think you can buy (here anyway) an aerosol which you discharge in the car with the AC on recirculate mode. It's not cheap but it's worked for me when all I could afford was used Ford wagon which had a similar problem. Gone - 2008 Stornoway Grey RRS 2.7 TDV6
ADO5TIMES Member Since: 06 Jul 2014 Location: stoke on trent Posts: 63 ![]() ![]() |
Thanks for the info. Will mention this to the garage, and see what they say. |
martyn05 Member Since: 13 Feb 2014 Location: Derby Posts: 324 ![]() ![]() ![]() |
Just had my AC flushed through and re-gassed. I think the garage charged me about £30 for the chemicals. 2006 RRS SC Bonatti Grey (the 55th car/van I have owned)
Gargy Member Since: 08 Jun 2014 Location: Gloucester Posts: 92 ![]() ![]() ![]() |
I work in the HVAC trade (Heating, Ventilation, Air Conditioning)
Took car to garage today and they put whet they call a "bomb" into the car with all the windows closed and run the ac on full for a while with air on recirc.
Yep, that's what I was referring to. If I were you, I would buy another one and do it again, in my experience a larger car needs more than one treatment. Keep the AC on all the time from now on and just adjust the temperature. Gone - 2008 Stornoway Grey RRS 2.7 TDV6
