Home > Technical > SMELL LEFT AFTER OPERATING AIR CONDITIONING
ADO5TIMES
2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Picked up my 2010 RRS from local garage on Monday and after using the ac for the first time today, when I returned to the car after a couple of hours there was only what I can describe as a strong stale urine like smell. Sad
was wondering if it maybe from the ac not being used for a while, or someone might be aware of another issue I may need to raise with the garage?
Any advice would be welcome.
Post #430748 Wed Jul 16 2014 9:29pm
BKHK
That's why in future you should always always have the AC climate control in, just adjust the temperature, never turn it off. You have some water in the system somewhere which has gone stale. I am not sure how to fix it, I think you can buy (here anyway) an aerosol which you discharge in the car with the AC on recirculate mode. It's not cheap but it's worked for me when all I could afford was used Ford wagon which had a similar problem. Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Post #430757 Wed Jul 16 2014 9:51pm
ADO5TIMES
Thanks for the info. Will mention this to the garage, and see what they say.
Post #430758 Wed Jul 16 2014 10:13pm
martyn05
Just had my AC flushed through and re-gassed. I think the garage charged me about £30 for the chemicals. 2006 RRS SC Bonatti Grey (the 55th car/van I have owned)
2005 GSX 1400 K5
Post #430775 Thu Jul 17 2014 7:02am
Gargy
England 2009 Range Rover Sport TDV8 HSE Santorini Black
I work in the HVAC trade (Heating, Ventilation, Air Conditioning)
There is a cooling coil which air passes over and cools the vehicles cabin. Through this coil passes the refrigerant at around 2 to 9 degrees C (Approx). With warm air passing over a cold coil (radiator grill) the coil sweats and drips. With this cycle going on over and over you get a build up of particulates on the coil. If the coil is unused for a while, the residue on the coil goes stagnant, which when the aircon is turned back on causes the odour in the cabin.
As for having the system flushed and re gassed................... This is a ploy to extract money from you for no reason. It's like saying you have to change the water in your heating system at home. They are both sealed systems, and should have all the correct gasses and oils/inhibitors to keep them healthy for life. Run the aircon for 10 minutes per month (Min) to stop the seals drying out, which will keep the refrigerant from leaking out through the seals.
Running the aircon system regularly is definitely advised to keep it in good working order. This applies to car, domestic and commercial systems.
Post #430781 Thu Jul 17 2014 8:48am
ADO5TIMES
Took car to garage today and they put whet they call a "bomb" into the car with all the windows closed and run the ac on full for a while with air on recirc.
When I collected the car later it smelt lovely and have left the ac on for the last 20 miles or so and its fine Thumbs Up
Post #430849 Thu Jul 17 2014 9:31pm
BKHK
Yep, that's what I was referring to. If I were you, I would buy another one and do it again, in my experience a larger car needs more than one treatment. Keep the AC on all the time from now on and just adjust the temperature. Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Post #430856 Thu Jul 17 2014 10:17pm
