Home > In Car Electronics > Switched Live - Under Bonnet |
ciw2032 Member Since: 20 Jun 2014 Location: Norwich Posts: 4 |
Hi, I am looking to install some Osram combined DRL/ Fog/ Cornering lamps in my 2012MY RRS. In order to complete the install I need to find a switched live for the secondary feed. I have checked the main fuse board but can only see constant lives. I would prefer not to go through the bulkhead if possible.
Thu Jul 03 2014 9:23am |
Sun Jul 06 2014 12:36pm |
d-a-n Member Since: 06 Apr 2014 Location: Dorset Posts: 13 |
Did this work ok for you, did you get the idea from my installation?
Tue Jul 15 2014 7:45am |
d-a-n - thank you yes it works a treat, indeed I did read your post for the solution on switched +ve. Apparently on the earlier RRS pin 14 on the headlight multi plug is switched but its not used on the MY12 (and maybe others)
Tue Jul 15 2014 8:57am |
Post a picture once your all done. |
Tue Jul 15 2014 1:48pm |
