Home > In Car Electronics > Switched Live - Under Bonnet
ciw2032
England 2012 Range Rover Sport SDV6 HSE Orkney Grey
Hi, I am looking to install some Osram combined DRL/ Fog/ Cornering lamps in my 2012MY RRS. In order to complete the install I need to find a switched live for the secondary feed. I have checked the main fuse board but can only see constant lives. I would prefer not to go through the bulkhead if possible.
http://www.osram.co.uk/osram_uk/products/l.../index.jsp
Any help or advice on where I can link onto a switched +ve would be appreciated
Many thanks in advance
Post #429204 Thu Jul 03 2014 9:23am
Paulcp
2013 Range Rover Sport SDV6 HSE Atacama Sand
Some fuses stay live for a short time after switching ignition off.
The only one that I found that is purely a switched live is the fuel pump, hence I took my switched live off this fuse using a piggy back fuse holder and wire.
Post #429226 Thu Jul 03 2014 3:36pm
ciw2032
Managed to find a feed with assistance from another thread, in front of the radiator and close to the horn is a socket which I believe is part of the loom for the adaptive cruise control (which is not fitted as an option to mine)
Post #429471 Sun Jul 06 2014 12:36pm
d-a-n
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Bali Blue
Did this work ok for you, did you get the idea from my installation?
http://www.rrsport.co.uk/forum/viewtopic.php?p=428408#428408
Post #430552 Tue Jul 15 2014 7:45am
ciw2032
d-a-n - thank you yes it works a treat, indeed I did read your post for the solution on switched +ve. Apparently on the earlier RRS pin 14 on the headlight multi plug is switched but its not used on the MY12 (and maybe others)
Anyway now all working as it should - there is an alternative cabling solution that allows the DRL to dim with the headlights on as opposed to switching off as I have them now. I will try that at the weekend and see how that looks.
They are certainly a nice piece of kit with the combined DRL and fog light functions (separate lights and reflectors) and the option to link into the cornering lights also
Post #430566 Tue Jul 15 2014 8:57am
d-a-n
Post a picture once your all done. Thumbs Up
Post #430612 Tue Jul 15 2014 1:48pm
