Home > Technical > We think its over fueling... does anyone know anything about |
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 |
Over fuelling ??? Does he mean you've got a faulty injector, get the fault codes read. Faulty injectors can burn out the piston which if left can take out the engine.. 2008 G4 RRSport TDV8 current
Mon Jul 14 2014 9:54pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8986 |
First thing to check is the intercooler hoses to make sure they haven't split or collapsed internally. 2012 SDV6 - it's missing a couple of cylinders
Tue Jul 15 2014 7:46am |
Ptang Member Since: 11 Jan 2008 Location: Bromley, Kent Posts: 95 |
Just my 2p - It also sounds like a possible misfuelling as you can have very similar symptoms when petrol is put in a diesel (yes, that is experience talking). Luckily for me I only put in 1/4 tank of petrol so was able to dilute with diesel repeatedly over the next few days without any lasting problems (so far!).
Tue Jul 15 2014 8:29am |
