![]() | Home > Technical > Engine fault |
Alex C Member Since: 09 Jun 2013 Location: Southampton Posts: 146 ![]() ![]() |
Which engine you running??
Paulfenn Member Since: 20 Apr 2014 Location: Kent Posts: 7 ![]() ![]() |
Hi, tdv8
Check the intercooler hoses, on the top of the engine, right in front of you. Mine had an inch long split underneath, there is a photo on here where I tried to patch it over with tape to get to a garage, didn't hold!! Noise sounded similar to what you have described, just losing all boost on one bank.
Many thanks for that, will check later.
