![]() | Home > General > Cigarette lighter doesn't charge phone |
Scorpius Member Since: 08 Jun 2014 Location: Bracknell Posts: 4 ![]() ![]() |
Have you checked the fuse hasn't blown, ie, does the standard cigar lighter work? |
Just read your post properly. Please ignore. |
Had this with rear lighter socket on mine when I Ran dual lead to Acc socket. Turned out that when I folded down rear seat, I pushed the plug in to socket. Took it to bits and found positive terminal misplaced so "re-adjusted" it. Funny enough my FF just did exactly the same thing. Lighter works, sat nav worked but USB type plug that you now get wouldn't as has ridge to prevent "over insertion" |
shakeapaw Member Since: 17 Dec 2011 Location: in a mud hut in wigan Posts: 948 ![]() ![]() ![]() |
I have had the same issue for the past 3 years, and have now given up, the lighter works as it should, it has had around 7 different phone chargers in it, and not one has worked ![]() ![]() |
