![]() | Home > In Car Electronics > Lost volume on Radio & SatNav |
bazalab Member Since: 03 Dec 2010 Location: Lymington, New Forest, Hampshire Posts: 37 ![]() ![]() ![]() |
Hi Guys
Sorry chaps should have mentioned my RRS is a 2006 HSE with 73k miles.
Hi Simon73
Just for info sake, had diagnostic done and Amplifier failed - new one on order as could not find any compatible with my 2006 sport on internet/ebay etc. £420 + Vat for Harmon Kardon unit plus labour to removal and replace front seat to afford access so expensive way to have noise again!!
Bladeboy Member Since: 17 Sep 2013 Location: Benson Posts: 522 ![]() ![]() ![]() |
I don't suppose you've recently fiddled with your Bluetooth module in the boot? I had the volume issue, and it turned out when fitting a new Bluetooth module I'd plugged one of the plugs back in backwards.
Thanks Bladeboy but no, I really know very little about these things so always leave well alone.
Hi Guys
Graz Member Since: 22 Apr 2013 Location: Essex Posts: 104 ![]() ![]() |
I had a similar issue this week. I had left the interior light on all night and when I started the car in the morning, there was no volume and I couldn't change the radio channels. After a 40 mins drive to work and a restart, it was fine. I presumed that the light had drained some of the battery and the system goes into self preservation and cuts power to non essentials until the alternator has recharged the battery. |
Charlielucas Member Since: 05 Dec 2014 Location: Essex Posts: 3 ![]() ![]() ![]() |
Hiya I've got same car n same problem can I ask if u know the order code for amp I've got to replace mine but don't know what one to order. Thanks |
