Home > General > How often should I drive it? |
martyn05 Member Since: 13 Feb 2014 Location: Derby Posts: 324 |
I would say once a week, a 30 min drive to move all the oils, charge battery, prevent tyre deformation, prevent dampness etc. Do you leave your handbrake on or off when parked at home?
Thu Jul 03 2014 1:46pm |
Bradders Member Since: 08 Oct 2009 Location: Leeds Posts: 2515 |
^^ all sound advice.
Thu Jul 03 2014 1:56pm |
muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5636 |
I had an MGTF that only did 2000 miles a year and my Brother had a RRS that was not used very often - we both had problems due to low usage and in the end sold them Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Thu Jul 03 2014 2:09pm |
Definitely a situation of... "Use it or loose it" - mechanically it will suffer premature failure of seals, electronics etc.
Thu Jul 03 2014 3:31pm |
myfirstrrs Member Since: 20 Jan 2014 Location: Lancashire Posts: 433 |
I don't know if this helps but my neighbours MY2007 TDV8 stood for just three weeks without being used and his turbo actuators stuck to the point where they could not be freed off, a very expensive body off repair followed. From reading on this forum that doesn't seem to have been an exception. Hence I don't let mine sit for more than about 10 days now without at least some use and I always feel better when it's had a motorway burn. |
Thu Jul 03 2014 3:34pm |
found this and worth a read
Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW Still hoping for a S2 one day! |
Thu Jul 03 2014 3:36pm |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
At least once a week and for minimum of 30 mins so fully warmed, don't be tempted to start it and let it idle, as already covered, mine had done very few miles in its early life, and that's when majority of failures took place. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Thu Jul 03 2014 7:57pm |
ilard Member Since: 20 Aug 2010 Location: London Posts: 975 |
I feel a bit of fool for not figuring this out for myself. But once again, great advice from this forum's members, many thanks! L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Thu Jul 03 2014 10:39pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8971 |
Don't forget to put it in low range occasionally too. Just drive it 50 yards in LR (and a bit of reverse too). Run the ride height through its full range too to keep the ride height sensors clean. 2012 SDV6 - it's missing a couple of cylinders
Fri Jul 04 2014 7:09am |
Never thought of that or done it
Fri Jul 04 2014 7:15am |
Sporting Chance Member Since: 08 Aug 2013 Location: Oxford Posts: 32 |
Diesel engines like to be worked.
Fri Jul 04 2014 9:52pm |
