Home > General > How often should I drive it?
ilard
I rarely need to use my car (3.0 TDV6 RRS 2011MY) and I have only covered 1,000 miles in the last 7 months Maya Gold
To keep the old girl in reasonable condition, how often should I take her out? i.e. what considerations should I put around:
* Frequency
* Duration of drive
* Distance
* Speed
* Diesel type
Your thoughts and experiences would be welcome! L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Post #429218 Thu Jul 03 2014 2:37pm
martyn05
I would say once a week, a 30 min drive to move all the oils, charge battery, prevent tyre deformation, prevent dampness etc. Do you leave your handbrake on or off when parked at home?
Like all mechanical objects, IMHO it would start to seize up if it is not used enough.
I rarely use mine but try once a week to give it a run out. 2006 RRS SC Bonatti Grey (the 55th car/van I have owned)
2005 GSX 1400 K5
Post #429219 Thu Jul 03 2014 2:46pm
Bradders
^^ all sound advice.
To be honest, if that mileage is indicative of use for the foreseeable future, would you not be better off selling it, especially give the fixed costs of car tax, servicing and insurance ? FF 4.4 V8 Soooo looking forward to this bad boy
Ex 2006 RRS SC - garbage
Ex 2016 135i M Sport - dream car
Ex 2003 RS6 Avant - piece of cr*p
Ex 2014 320d X Drive, M Sport Touring - ok I guess
Ex 2007 RRS TDV8 - bloody loved it
EX 2007 FL2 XS - not so bad
Post #429221 Thu Jul 03 2014 2:56pm
muddywheels
Milk Float Man
I had an MGTF that only did 2000 miles a year and my Brother had a RRS that was not used very often - we both had problems due to low usage and in the end sold them Sad Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #429222 Thu Jul 03 2014 3:09pm
drdelrrs
Definitely a situation of... "Use it or loose it" - mechanically it will suffer premature failure of seals, electronics etc.
If costs aren't of concern then wouldn't it be better to hire one when you needed it?
Post #429224 Thu Jul 03 2014 4:31pm
myfirstrrs
I don't know if this helps but my neighbours MY2007 TDV8 stood for just three weeks without being used and his turbo actuators stuck to the point where they could not be freed off, a very expensive body off repair followed. From reading on this forum that doesn't seem to have been an exception. Hence I don't let mine sit for more than about 10 days now without at least some use and I always feel better when it's had a motorway burn.
Post #429225 Thu Jul 03 2014 4:34pm
muddywheels
Milk Float Man
found this and worth a read Thumbs Up
http://www.racq.com.au/motoring/cars/car_a...g_your_car
Quote:
Without doubt the best way to store a vehicle is to not store it at all, but have someone you trust drive it regularly. Preferably this should be weekly for about 30 minutes to allow everything to reach operating temperature and to circulate oils and fluids. This use, while infrequent, offers the best chance of ensuring that everything continues to operate properly. Inevitably, however, things will go wrong simply through normal wear and tear. Do not overlook the fact that regular servicing will be required, even when the vehicle doesn’t travel any significant distance. Servicing should be scheduled for every six months even if the vehicle hasn’t travelled the required distance.
Post #429227 Thu Jul 03 2014 4:36pm
simple1
At least once a week and for minimum of 30 mins so fully warmed, don't be tempted to start it and let it idle, as already covered, mine had done very few miles in its early life, and that's when majority of failures took place. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #429252 Thu Jul 03 2014 8:57pm
ilard
I feel a bit of fool for not figuring this out for myself. But once again, great advice from this forum's members, many thanks! Thumbs Up L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Post #429279 Thu Jul 03 2014 11:39pm
Don't forget to put it in low range occasionally too. Just drive it 50 yards in LR (and a bit of reverse too). Run the ride height through its full range too to keep the ride height sensors clean. 2012 SDV6 - it's missing a couple of cylinders
Post #429291 Fri Jul 04 2014 8:09am
muddywheels
Milk Float Man
Never thought of that or done it Shocked
Guess what I'm doing today Laughing Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #429292 Fri Jul 04 2014 8:15am
Sporting Chance
England 2010 Range Rover Sport TDV8 HSE Santorini Black
Diesel engines like to be worked.
They have to be worked, that is what they were designed to do.
A good blow out once in a while will do the engine good. Current 2010 RRS TDV8
Gone 2009 D3 HSE TDV6
Gone 50th anniversary Defender
Gone 1992 Defender 200 TDI
Gone 1988 Defender TD
Gone 1979 Series 111 V6 Steve Parker conversion
Post #429350 Fri Jul 04 2014 10:52pm
