![]() | Home > Technical > Air Compressor Removal |
accyis Member Since: 05 Feb 2010 Location: Lancashire Posts: 109 ![]() ![]() ![]() |
Is there a post for the compressor removal out there that anyone could point me to |
Shaun75750 Member Since: 27 Jun 2012 Location: Staffordshire Posts: 12 ![]() ![]() |
I changed mine to the new amk one
panda Member Since: 17 Jan 2010 Location: london Posts: 702 ![]() ![]() |
Hi accyis
Thanks for the input that's great but can anyone answer the questions in the initial post with regards to the removal causing issues etc. |
SCdavies Member Since: 28 Dec 2010 Location: south coast Posts: 324 ![]() ![]() ![]() |
Car will stay at height.mine did anyway. Do not drive or start engine while pump is off. New software not always required. If operates ok when reinstalled all is well. |
That's great thanks just what i was looking for. |
IDB Member Since: 09 May 2013 Location: Chorley, Lancs Posts: 18 ![]() ![]() ![]() |
Hi accyis, did you manage to ge the compressor off and refurb it? just looking at doing mine and to be honest its looks near impossible to get the to the fixing bolts, top one in particular let alone strip the thing down without stripping any of the threads, good old steel/aluminium corrosion for you going on there.
Hiya. Sadly I haven't had the time yet as it's my wife's car. I was going to remove it myself and then send the compressor away for a refurb (advertised on ebay) but I would be looking at few days to turn it round. At present the access height can still be achieved once the ignition has been turned off and I still have full operation of height adjustment if I select it within 30 seconds of turning ignition on.
cossiedave Member Since: 20 Jun 2012 Location: lancaster Posts: 882 ![]() ![]() ![]() |
i have done a few and they are pretty easy to get off if all comes off, about 30 minutes tops but if bolts seized in and air pipes seised and need cutting off it will take you well over an hour, i have one to do on saturday thats all seized up so i will report back to let you know how long it took me to change it |
That doesn't sound too bad, the fixing bolts on mine look pretty rusty. Even the bottom cover screws were an issue, only managed to undo 2 of them and had to cut off the 3rd.
