Home > Technical > Air Compressor Removal
accyis
United Kingdom 2006 Range Rover Sport TDV6 HSE Zermatt Silver
Hi
I am looking at removing my air compressor to recondition and have found plenty of info on here. The one question I have is how does the removal of the compressor affect the vehicle.
Does the suspension drop or does it hold in the position last left?
Can the vehicle be driven/ moved safely?
Can it be unplugged and plugged back in without any software update.
Any other info really welcome.
Thanks for reading.
Nick
Post #425324 Mon May 26 2014 7:43pm
accyis
Is there a post for the compressor removal out there that anyone could point me to
Post #425396 Tue May 27 2014 3:12pm
Shaun75750
2005 Range Rover Sport TDV6 HSE Bonatti Grey
I changed mine to the new amk one
There is a how to replace the compressor
On the disco 3 site
Post #425398 Tue May 27 2014 3:20pm
panda
Hi accyis
Try Home page
Technical
Definitive list of "HOW TOs"
That should help.
Thumbs Up Thumbs Up
PANDA
Post #425405 Tue May 27 2014 4:23pm
accyis
Thanks for the input that's great but can anyone answer the questions in the initial post with regards to the removal causing issues etc.
Post #425414 Tue May 27 2014 5:43pm
SCdavies
England 2006 Range Rover Sport Supercharged Zambezi Silver
Car will stay at height.mine did anyway. Do not drive or start engine while pump is off. New software not always required. If operates ok when reinstalled all is well.
Post #425420 Tue May 27 2014 7:03pm
accyis
That's great thanks just what i was looking for.
Post #425424 Tue May 27 2014 7:49pm
IDB
England 2006 Range Rover Sport TDV6 HSE Zermatt Silver
Hi accyis, did you manage to ge the compressor off and refurb it? just looking at doing mine and to be honest its looks near impossible to get the to the fixing bolts, top one in particular let alone strip the thing down without stripping any of the threads, good old steel/aluminium corrosion for you going on there.
Ian Also Honda CB500 Four K2 (1973)
Post #428075 Mon Jun 23 2014 12:14pm
accyis
Hiya. Sadly I haven't had the time yet as it's my wife's car. I was going to remove it myself and then send the compressor away for a refurb (advertised on ebay) but I would be looking at few days to turn it round. At present the access height can still be achieved once the ignition has been turned off and I still have full operation of height adjustment if I select it within 30 seconds of turning ignition on.
I may end up at my local indie garage, I suppose I'm just holding off the inevitable.
What sort of cost would you expect for a compressor replacement?
Post #428213 Tue Jun 24 2014 5:37pm
cossiedave
England 2006 Range Rover Sport TDV6 Autobiography Zambezi Silver
i have done a few and they are pretty easy to get off if all comes off, about 30 minutes tops but if bolts seized in and air pipes seised and need cutting off it will take you well over an hour, i have one to do on saturday thats all seized up so i will report back to let you know how long it took me to change it
Post #428232 Tue Jun 24 2014 8:05pm
IDB
That doesn't sound too bad, the fixing bolts on mine look pretty rusty. Even the bottom cover screws were an issue, only managed to undo 2 of them and had to cut off the 3rd.
Have you managed to refub any compressors or have you just swapped them out for the AMK compressor?
The more I read the more complex it looks as it doean't necessarily mean that replacing the piston seal and drier kit fixes the probelm as I understand the exhaust valve can also cause issues? Also Honda CB500 Four K2 (1973)
Post #428234 Tue Jun 24 2014 8:23pm
