Home > Technical > Fuel flap unlocking squeal!
Andi
Started getting a little squeal when unlocking the car, if I put my ear close to the fuel flap it sounds like it's coming from there. Any ideas what this can be? Is it easy to get to this? Any help greatly appreciated saving me a trip to the dealers.
Thanks, Andi
Post #427859 Sat Jun 21 2014 9:30am
martyn05
can it be the locking pin that goes into the fuel flap? Possibly spray wd40 on the end of the locking pin? Maybe its the fuel flap actuator that it is on its way out. 2006 RRS SC Bonatti Grey (the 55th car/van I have owned)
2005 GSX 1400 K5
Post #427920 Sat Jun 21 2014 10:18pm
Andi
Thanks for the reply, I have given it a good coating of WD40, but I think it is the actuator that makes the noise. Do you know if it's easy to get to?
Post #427927 Sun Jun 22 2014 6:17am
martyn05
Pull the flap off inside the boot, you should be able to see the cable etc from them, you might need a torch. 2006 RRS SC Bonatti Grey (the 55th car/van I have owned)
2005 GSX 1400 K5
Post #427944 Sun Jun 22 2014 9:13am
Andi
Thanks mate, I will take a look. Thumbs Up
Post #427959 Sun Jun 22 2014 10:31am
martyn05
Did you find anything? Sit in the boot with the tailgate shut then operate the remote locking. You might see or hear more looking into the area where the actuator and cable are located. 2006 RRS SC Bonatti Grey (the 55th car/van I have owned)
2005 GSX 1400 K5
Post #427964 Sun Jun 22 2014 11:15am
Andi
Sprayed wd40 all over the locking pin then all around the cable etc inside the panel and the squeal has gone. Thanks for the help mate. Thumbs Up
Post #427984 Sun Jun 22 2014 5:01pm
martyn05
Thumbs Up 2006 RRS SC Bonatti Grey (the 55th car/van I have owned)
2005 GSX 1400 K5
Post #427998 Sun Jun 22 2014 7:22pm
Andi
Bad news, the squeal is back! Bloody thing Shocked
Post #428056 Mon Jun 23 2014 10:11am
martyn05
was it the cable or the actuator making the noise? 2006 RRS SC Bonatti Grey (the 55th car/van I have owned)
2005 GSX 1400 K5
Post #428081 Mon Jun 23 2014 2:43pm
Andi
Almost definitely the actuator, if you put your ear to the car, just above the fuel flap and to the right, that's where the sound comes from. Strange thing is, it only seems to do it in the morning!!
Post #428096 Mon Jun 23 2014 6:34pm
CUCO
Spain
try to use a heavier oil that "grips" to surface, like white motorcycle chain grease, they sell it in cans, that are liquid to penetrate and after a while it gets harder and tacky, the helps a lot avoiding squeaks when WD40 dont do the trick.
Post #428227 Tue Jun 24 2014 7:09pm
