Home > General > Warranty issues |
hoppy_70 Member Since: 28 Mar 2009 Location: United Kingdom Posts: 437 |
That's just poor service. Not all dealers are the same. I had a similar problem on a full fat with flickering headlamps. Guy salmon said "supposed to do that sir, it's characteristic" where as stratstone correctly diagnosed a fault and replaced both headlamps.
Fri Jun 20 2014 3:50pm |
Chin Member Since: 02 Sep 2013 Location: London, UK Posts: 66 |
does anyone know if the approved used warranty is provided by land rover, or by a third party?
Fri Jun 20 2014 4:21pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8977 |
Car Care Plan 2012 SDV6 - it's missing a couple of cylinders
Fri Jun 20 2014 4:40pm |
RRS Daz Member Since: 22 Jan 2012 Location: Yorkshire Posts: 797 |
Just add it to the list of bad customer service from land rover.
Fri Jun 20 2014 7:23pm |
They will certainly feel the wrath of social media /letters of complaint soon enough.
Fri Jun 20 2014 7:58pm |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
Get in touch with Customer Relations, throw a polite tantrum and then ask to escalate to executive office as this all sounds like BS. If they feel you have been wrongly refused, they will put pressure on Carcare Plan to get work done. Software updates are not usually covered as dealership should provide this gratis if there has been an update 2x TDV6. SE and HSE. Both returned to sender with issues👀
Sat Jun 21 2014 5:20am |
If you read the handbook that comes with the warranty, you'll see what they state is not covered. Software upgrades aren't covered unless part of a repair to something else.
Sat Jun 21 2014 7:40am |
Yes seen in the hand book about software update.
Sat Jun 21 2014 8:04am |
nigel52 Member Since: 20 Nov 2013 Location: Farnham Posts: 274 |
I read all these issues and I am seriously considering selling my2011 RRS and going to something from Merc great service, warranty and support or Hyundai Santa Fe. Don't all be shocked but what does LR expect. Eventually it will come home to roost. |
Sat Jun 21 2014 8:35am |
A2LUA Member Since: 02 Jul 2011 Location: Cumbria Posts: 16 |
Hi I had the same problem with the fuel sender they tried the software update but this didn't work so the fuel sender in the tank had to be changed apparently theres a modded part and a fairly common fault all under the approved used warranty. |
Sat Jun 21 2014 9:04am |
Great thanks all.
Sat Jun 21 2014 10:23am |
whippetman Member Since: 12 Jun 2010 Location: on the level Posts: 500 |
Yep. Had my fuel tank sensors changed recently under extended warranty (2011) no quibbles |
Sat Jun 21 2014 1:32pm |
Thanks - can someone help explain why they pay out for some customers but not others?
Sat Jun 21 2014 8:17pm |
I guess there is a difference between the way different dealers approach the warranty company. The warranty company only want to pay for stuff that's failed, generally, so if a dealer says "the part is worn" they probably say "no". If the dealer says "the part has failed" then they pay out. I think they also send out assessors to check that stuff does need doing. Maybe it depends on a combination of things.
Sun Jun 22 2014 9:13am |
