![]() | Home > General > Detachable towbar won't fit |
sagalout Member Since: 26 Feb 2013 Location: Harrogate Posts: 128 ![]() |
Does anyone know if the LR detachable towbar is the same across all models? I purchased on on ebay which was listed as D3/D4 and RR Sport compatible, but the metal lug that goes in and out as you turn the handle won't go in far enough to seat in the receiving bracket. I'm wondering if its the wrong towbar or somehow faulty?
codfather Member Since: 13 Feb 2010 Location: ayr Posts: 1171 ![]() ![]() ![]() |
Yes it should retract, looks like it is seized. Get some WD40 in the joints and see if that helps. The small pin at the top triggers the bigger bolt shown to lock into place
Thanks for that - just gave it a good dowsing in wd40 and its retracting fully now |
Now it's all free, take it off again and give it the same good dousing in spray grease, otherwise it's a real pita to get off again. |
tonytiger Member Since: 14 Sep 2013 Location: St.Neots. Cambs Posts: 308 ![]() ![]() ![]() |
When fitted are they rock solid?? Or is there any movement?? Thx tt 2010 TDV8 Bali Blue........ "Alive Tuned"
martyn05 Member Since: 13 Feb 2014 Location: Derby Posts: 324 ![]() ![]() ![]() |
solid 2006 RRS SC Bonatti Grey (the 55th car/van I have owned)
Ollyhall Member Since: 30 Aug 2015 Location: Portsmouth Posts: 13 ![]() ![]() |
I'm having the same problem, do you need the keys to fit a tow bar? I'm wondering if mine has come with the wrong keys some how? |
Yes, you must have the key. |
lamb190 Member Since: 12 Jun 2015 Location: bristol Posts: 80 ![]() ![]() ![]() |
MAKE SURE YOU "PULL" the green lever as well as twist it! (you need key in and turned) |
Lamb you just saved me from launching the thing down the road! Wondered what that arrow ment hahaha thanks buddy |
Bladeboy Member Since: 17 Sep 2013 Location: Benson Posts: 522 ![]() ![]() ![]() |
On a similar vain, my key won't come out when it's fitted. Apart from making it very nickable, is it safe to tow with the key in?
im glad i could help..... from experience see! as i had the same issue!
Mines all fitted now, I used wd40 on all the parts, and bought some nice thick grease to lube the hole and shaft that why removal should be easier, key popped out fine after this it is worrying tho as I'm picking a new caravan up Saturday hope she don't fall offlol |
im sure you can tow in confidence.
