![]() | Home > Maintenance & Modifications > Suspension creaking |
Hugh Haddow Member Since: 03 Jul 2009 Location: Prestwick Posts: 202 ![]() ![]() ![]() |
Don't really know how to describe this but here goes. 12 model with 55k ish under its floor pan. It has started an intermittent creaking from the front drivers side I think. Typically low speed over rough ground when some steering is applied. You hear and feel it in the inside but it is not noticeable externally. A sort of vibration more than anything else. I think I've also noticed it when breaking with a turn. Generally on the straight it is fine.
Thanks Essexfarmer. Yes I will take it to the dealer but I like to get an opinion from the forum first. I find it helps in case they try to baffle me with engineering or something.
