Home > Maintenance & Modifications > Suspension creaking
Hugh Haddow
Scotland 2013 Range Rover Sport 3.0 TDV6 HSE Bali Blue
Suspension creaking
Don't really know how to describe this but here goes. 12 model with 55k ish under its floor pan. It has started an intermittent creaking from the front drivers side I think. Typically low speed over rough ground when some steering is applied. You hear and feel it in the inside but it is not noticeable externally. A sort of vibration more than anything else. I think I've also noticed it when breaking with a turn. Generally on the straight it is fine.
In my mind it seems like a 'dry' rubber bush.
Thoughts and suggestions welcome.
Hugh
Post #427549 Wed Jun 18 2014 2:44pm
essexfarmer
United Kingdom 2012 Range Rover Sport SDV6 HSE Lux Orkney Grey
Hi Hugh,
Mine did that last year with a lot less miles on it, sent it back to the dealer and they replaced something on the suspension, unfortunately I can't remember what. Not much help, sorry, but if I were you and as it is still under warrantee, I would take it back to the dealer.
Shaun 12MY RRS Orkney Grey HSE Lux
12MY FF Santorini Black VSE
Post #427580 Wed Jun 18 2014 6:14pm
Hugh Haddow
Thanks Essexfarmer. Yes I will take it to the dealer but I like to get an opinion from the forum first. I find it helps in case they try to baffle me with engineering or something.
Hugh
Post #427611 Wed Jun 18 2014 10:51pm
