![]() | Home > Technical > Loss of acceleration |
artictruckgirl Member Since: 31 May 2014 Location: Montesquiou Posts: 7 ![]() ![]() ![]() |
Hello
Stuck Exhaust Gas Recirculating valve (EGRs) at a guess. |
tailormadefun Member Since: 06 Apr 2014 Location: Kent Posts: 51 ![]() ![]() ![]() |
could be a faulty fuel return valve |
Thanks both of you, I have the phone number of a guy over here to chat too on Monday, I will put both of your ideas to him.
Thanks Ady
Sorry to hear about your problems. I have a similar problem were my Sport is, I give some thought to buying one of these
Diamond155 Member Since: 18 Aug 2015 Location: West Mersea Posts: 4 ![]() ![]() ![]() |
Hi
CTF Member Since: 10 Dec 2014 Location: Suffolk Posts: 9 ![]() ![]() ![]() |
Thanks diamond155. I have the same power loss problem. After braking go to accelerate but there is briefly no power, nor any warning lights. Worked out that it never happened when wearing shorts. Will try rolling jeans up and see if it sorts problem. |
Boost Member Since: 18 Aug 2011 Location: North Lincolnshire Posts: 60 ![]() ![]() ![]() |
Sounds the same symptoms I had the other week and it was EGR valves. Blanked off now and all OK |
gary3306 Member Since: 04 Feb 2015 Location: Northumberland Posts: 210 ![]() ![]() ![]() |
I've just ordered a blanking kit. Little bit sluggish pulling away. Letting my engine breath what it was designed to breath (fresh air) and not the crap it's forced to breath, can only do good. The EGR system is the worst design to come to modern engines EVER. |
