  • You are currently viewing RRSPORT.CO.UK as a guest - Register to take part or Log In
Home > General > *help* Headlight lense removal
kenti4264
United Kingdom 2006 Range Rover Sport Supercharged HST Santorini Black
hello
just looking for abit of advice. im wanting to remove the lense on the headlights of my RRS as im wanting to paint them black. was looking for a cheap pair on ebay in order to practice on but they dont seem to be cheap. any body help me
thanks
Post #425648 Fri May 30 2014 7:31am
simple1
Time to take a look at previous posting where a member can supply what you want or else you are going to need a large oven to heat the glue to about 300 degrees.
Might be an idea to talk to a local window tinter if you don't fancy that much open surgery, I had mine covered in a mesh that darkens standard lights
 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #425649 Fri May 30 2014 7:34am
RRS Daz
It's easy.
You just need a heat gun and a wall paper scraper (don't use a screw driver as it's will cause damage).
Just lightly heat and keep trying to seperate they will split you just have to be gentle.
Post #425651 Fri May 30 2014 7:44am
RRS Daz
Have you been using your secret stash of women's tights again?
Post #425653 Fri May 30 2014 7:45am
simple1
Yep Thumbs Up sticky back tights in true blue peter stylie Bow down 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #425654 Fri May 30 2014 7:47am
drdelrrs
Don't wish to be a kill-joy but are the 'tinted' or modified lights still legal.
Apart from the law your insurers might consider this a modification and if you didn't tell them you could find yourself with a nasty surprise especially if the incident involved in a prang that the cops attended.
Post #425662 Fri May 30 2014 9:24am
simple1
They are not tinted, it's a mesh therefore conforms to legal requirements and doesn't reduce the emitted light. Not even bothering to get into the "have you informed your insurance company" crap. Rolling Eyes 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #425665 Fri May 30 2014 9:43am
drdelrrs
Language a bit harsh - Simple1 "Not even bothering to get into the "have you informed your insurance company" crap."
Not sure its '...crap...' when insurance fraud and the cost of accidents is running high and we are well aware that insurers are making good use of their small print: everyone will make their own decision.
It would be really easy to ring a broker and see if this 'mod' was something or nothing
Post #425689 Fri May 30 2014 1:09pm
sparky8181
Really simple, all you need is a heat gun and a bit of time.
Heat all they way round and then when you think its hot enough heat it some more just to be sure, then remove one of the round caps that you would remove to replace a bulb, this gives you somewhere to get a decent grip and slowly pull it apart whilst heating it some more as you go along.
Little tip for you though, don't stretch the sealant too far as you will end up getting in a mess and it wont be even when you come to stick it back together, I've found (and ive done this a few times now lol) that the best way is to prize it open about an inch and using old scissors cut through the sealant so it stays evenly around the rim. It makes for a much easier and tidier job Thumbs Up
Post #425713 Fri May 30 2014 4:06pm
Russben
Are you wanting to paint the lens or the inside of the lamp black?
I'm presuming it's the inside of the body you are painting otherwise you wouldn't need to take the lens off, you'd just spray the front of the lamp plastic/glass.
Painting the inside of the lamp body wouldn't affect light output so you shouldn't need to inform your insurers. So long as you haven't altered the beam it will still pass an MOT too. I'm in the shed, I'll be back in the real world in a minute.
Post #425719 Fri May 30 2014 5:09pm
simple1
Whistle think the word rhymes with Banker.... Sheep 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #425722 Fri May 30 2014 6:00pm
daveyc
United Kingdom 2006 Range Rover Sport Supercharged Siberian Silver
Hi ive just done a set so I could fit the angel eyes , I used a good hair dryer just be careful not to over heat if you use a heat gun or you will melt the plastic and slow pressure all round if you rush it will crack remember to take the little black clips off first also the mounting bracket as it get in the way of the front lens clip , just the reverse to stick them back together ... 2006 Hst 4.2 Supercharged , Angel eyes , 2010 rear led lights , indicator / courtesy wing mirror leds, Khan 21" Diamond edition split rims, full spec (running LPG �0.60 per ltr)
2007 2.7 v6 Chrysler Sebring convert sport
2006 SRT8 6.1 ltr petrol 300 Chrysler gone
2005 X5 3.0d sport gone
2001 BMW 330 ci ltd edition mtec gone
Post #426464 Fri Jun 06 2014 7:18pm
panda
maybe this will help copy paste into search Clear Front Reflectors How To
Panda
Post #426470 Fri Jun 06 2014 9:36pm
