Home > Technical > Air Con Not Working
Stuart
Air Con Not Working
When I got the car a few months ago, I tried the aircon and decided it wasn't working.
When I bunged it in for a service (indy specialist) , I told him to check it out as it wasn't cooling, he says, "How do you know? It is too cold to know?" Rolling with laughter
Well, you just know don't you?
So when I collected the car, he tells me they looked at it, everything is kicking in as it should, they gassed it a little, and he said lets look at it again when its warmer to be sure.
Well, now its warmer, and it doesn't bl00dy work like I said.
So going off what he said, the mechanicals seem to work visually, absent a leak, it has gas, set it to auto inside the cabin and it blows like a good un, suggesting sensor side is OK, just not cool air.
Is there any component that is known to go that these symptoms are typical of?
I didnt want to book it in, and £££'s later someone say "Oh, you just change fuse number twelve mate, its always that. Everyone knows that".
So I thought I would ask first in case its a known fault.
Post #424458 Thu May 15 2014 9:03pm
Gibbsy1966
England 2011 Range Rover Sport 3.0 TDV6 HSE Lux Sumatra Black
Hi
No expert but I had the same problem turned out to be a small hole in the colling radiator...needed a replacement...all's great since then BMW 530D 2011 still here
Porsche Boxster S gone - RRS Supercharged bought to transport 2 Tibetan Terriers!!
Post #424489 Fri May 16 2014 10:49am
Stuart
Thanks Gibbsy. It looks like its a garage job then.
Post #424516 Fri May 16 2014 5:49pm
Stuart
Gibbsy1966 wrote:
I had the same problem turned out to be a small hole in the cooling radiator..
Same problem here it turned out.
Post #425169 Sat May 24 2014 5:21pm
Bungleaio
2005 Range Rover Sport Supercharged Buckingham Blue
Out of interest how much did a new radiator set you back? Mine doesn't blow cold either.
Post #425183 Sat May 24 2014 8:24pm
Stuart
It isn't ready till Tuesday after the holiday.
I didn't ask the price - I just said do it as it needs doing. It is in the indy Landranger in Stockport. They seem OK.
I'll report back with the price.
Post #425194 Sun May 25 2014 1:16am
Bungleaio
Nice one, sometimes it's just best not to ask the price and put your pin number in Smile
Post #425214 Sun May 25 2014 10:43am
Stuart
£486 all in.
And now it also needs a suspension compressor. Big Cry
Post #425411 Tue May 27 2014 5:01pm
