Home > Maintenance & Modifications > TDV6 crankshaft notice
Just noticed this on Disco3.co.uk. Might be of interest to members here to:
http://www.disco3.co.uk/forum/topic111733.html
Quote:
Reference SSM71816
Models
Discovery 4 / L319
Discovery 3 / L319
Range Rover / L405
Range Rover Sport / L494
Range Rover Sport / L320
Title Crankshaft/Crankshaft Bearing Concerns - TDv6 Diesel Engine
Category Engine
Last modified 06-May-2014 00:00:00
Symptom 499000 Basic Engine
Content
Issue:
Crankshaft/crankshaft bearing failure - TDv6 Diesel Engine.
Cause:
Low incidence of crankshaft failure are being encountered, caused mainly by incorrect location of the main bearing shells during assembly, or through rotation of the shells during normal use. A new procedure has been implemented to ensure:
- more rapid resolution of customer concerns, and
- greater visibility of failure modes in order to improve repair process and parts delivery.
Action:
For any suspected crankshaft/bearing failure, please contact your local Dealer Technical Supportor FRED team for details of the enhanced customer handling procedure.
The list below summarises typical symptoms of crankshaft/bearing failure, but please contact your DTS/FRED team if in any doubt as they will be pleased to offer assistance:
· Crankshaft is seized, engine cannot be turned either via starter motor or crankshaft pulley bolt.
· Oil sump or engine cylinder block is holed, with oil leakage and/or metallic debris found on engine under-tray.
· Engine makes a loud ‘rumbling/knocking’ sound when running which worsens as the engine is placed under load. The engine oil pressure warning light may flash or be continuously illuminated, especially at low engine speeds.
 2012 SDV6 - it's missing a couple of cylinders
Post #423662 Thu May 08 2014 1:20pm
gazzc
2005 Range Rover Sport TDV6 HSE Siberian Silver
Big Cry gutted just spent 2800 rebuilding mine silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Rimini red rrs 2.7 tdv6 steps. Full c code. Recon engine!!loved but!gone ,thank god !!
Gone rr sport supercharged. Loved but 11mpg !!!
current,triumph stag mk2...current bmw 325 sport convertible
Post #423688 Thu May 08 2014 5:54pm
