Home > General > Suspension lowering overnight |
SCdavies Member Since: 28 Dec 2010 Location: south coast Posts: 324 |
It should nt do it on it's own accord. What year do you have? Was it down to it's bump stops? Very low? |
Tue May 06 2014 8:00pm |
simonk Member Since: 20 Apr 2014 Location: Rotherham Posts: 46 |
It's a 2008 TDV8, it's been left 2 hours now and it's still ok, it was all the way down |
Tue May 06 2014 8:04pm |
If it was down to the bump stops then I'm afraid you have an air leak. Not a bad one as you say it takes a night to lower itself. It's still ok to use as the pump is not saying car rising slowly etc. Try raising the car to extended level and leave overnight and see what happens. |
Tue May 06 2014 8:20pm |
Cheers going to raise it up now to high level and see what it's like in the morning, I have a 3 month warranty with it so will see what they have to say |
Tue May 06 2014 8:23pm |
Raised it to high level and got the message car rising slowly, is this normal? It may be due to me raising and lowering it a few times and emptying the air out the system?
Tue May 06 2014 9:16pm |
we lifted upto off road height last night, came out this morning and it hasn't moved a mm, this was confirmed when i started it up it didn't lift anymore and nothing to say it was rising.
Wed May 07 2014 7:42am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8958 |
Could be a ride height sensor playing up. The vehicle wakes up periodically and levels itself. As it can only level downwards with the engine off, you end up with the vehicle lowering overnight. By putting it in off road height you put the sensors in a different position which might prevent one reading incorrectly. This same thing happened with mine - no drop in off road mode.
Wed May 07 2014 7:58am |
Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852 |
Simon,
Wed May 07 2014 8:00am |
thanks for the advice, i have got it booked back in with the dealer that sold it to me , i had the balancing done today on it as i was getting a vibration at 70mph, its come back with 2 x slightly buckled wheels, 1 x tyre on the legal limit, 1 x tyre is a pirelli PZ zero and the others are pirelli scorpion Zero's, plus all the wheel nuts have expanded due to corrosion.and the spare is a 19" tyre compared to 20" on the rest of the car.
Wed May 07 2014 10:19am |
19 is a standard spare wheel on our cars. Just get the dealer to sort all your issues out or get a refund and buy another one. Good luck and keep us posted. |
Wed May 07 2014 12:56pm |
oh and tyre pattern wont damage anything. As long as its the same size. |
Wed May 07 2014 12:58pm |
Balancing won't remove the buckle but it might reduce the symptoms experienced - the steering wheel vibration. 2012 SDV6 - it's missing a couple of cylinders
Wed May 07 2014 1:09pm |
thanks for the replies,
Wed May 07 2014 2:38pm |
It is possible for different makes of tyre to be different sizes even though they are of the same size classification according to the sidewall info. As both of your tyres are from Pirelli, it's likely that they'll be close enough not to be a problem. Look elsewhere on the forum for a picture of two tyres that are the same size classification but obviously very different in actual size.
Wed May 07 2014 2:51pm |
