Home > General (L494) > Red Brakes
slim_sane
United Kingdom 2013 Range Rover Sport SDV6 HSE Santorini Black
Red Brakes
Just wanted to get a feel as to whether there is a common issue with the rear red brake calipers. I've had my car since the 1st March and it's only done about 450 miles (I know but I've not been around), but I noticed early on that the rear brake calipers have a lot of paint defects in that especially on corners and creases the paint is actually chipping off such that the base metal of the caliper is showing:
I took my car back to the dealer who agreed it was a defect and ordered another pair of calipers and booked the car in for replacement. Great right, however when they went to fit the calipers and opened the parts they were in the same condition as those already on the car Shocked . Now, the dealer is ordering up another set of calipers and seeing what condition they arrive in, if it's the same again then they'll have to take it up with Landrover directly Sad
I really can't see why they cheap'ed out on the rear calipers and simply got their component supplier to paint the standard caliper, when the finish of that component is obviously not suited to hold a paint coating without extensive work. The finish on the calipers is quite bad in general they should have gone for the matching brembo enamel finish which is smooth but as you can see the rears are more like you got a tin of paint from halfords and did it yourself.
Anyway that aside, I just wanted to gauge if this is a more common issue, so if you have this as well let me know Thumbs Up
Post #423187 Sun May 04 2014 7:29am
There is a thread about the quality and colour mismatch between calipers. Use the Search function at the top of the page. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #423189 Sun May 04 2014 7:53am
slim_sane
Yep thanks I know the quality has been discussed but I'm really trying to gauge if this defect (paint chipping) is more widespread other than the aesthetics of the colour matching.
Post #423190 Sun May 04 2014 8:01am
jim4244
England 2013 Range Rover Sport SDV6 HSE Santorini Black
Yes, mine has the same problem and is due to go back to the dealers for new calipers.
Jim
Post #423193 Sun May 04 2014 9:49am
slim_sane
Jim, let me know how you get on Big Cry
Post #423197 Sun May 04 2014 10:28am
andman
Andorra 2011 Range Rover Sport 3.0 TDV6 HSE Fuji White
LR customer relations thread pretty much covers it...
Im sure going to be Censored if mine turns up like that.....I expect enamel on both !!
Thx RRSTDV8 2014.5 SDV6 AB Dynamic ... Fuji /Santorini Pan roof and 22's
2013 Porsche Boxster S 3.4
2014 Audi A3 S line Quattro
Post #423199 Sun May 04 2014 11:09am
jim4244
The rear ones appear to have just been sprayed with normal red paint.........
Jim
Post #423201 Sun May 04 2014 11:47am
andman
Really glad you posted again here in General Slim.....
The CR post had escaped me !! 2014.5 SDV6 AB Dynamic ... Fuji /Santorini Pan roof and 22's
Post #423238 Mon May 05 2014 6:57am
RobF
It appears that LR have a problem with paint adhesion on the calipers, looks like the rear is the biggest issue.
They have also changed the spec on the standard caliper from Black to 'metallic' (ie, unpainted). Connected?
Post #423241 Mon May 05 2014 7:11am
andman
Any updates from anyone with the defective paint on the rear red brake calipers
Anyone had better quality painted , replacement ones fitted..... Have LR and the supplier addressed the problem... 2014.5 SDV6 AB Dynamic ... Fuji /Santorini Pan roof and 22's
Post #430291 Sun Jul 13 2014 6:35am
slim_sane
It's taken 2 months waiting for my replacement parts (which were coming from a new supplier - apparently), which were fitted a week back.
However both me and my dealer are not convinced that the finish on the new ones are any different, in fact they have suggested I will probably be back in a few months with the same issue. Given this scenario, they have already raise a product quality case with Landrover and sent my old ones back to them, the case will also remain open until I feedback on progress with the new ones.
So sorry no good news currently Big Cry but I'll keep you posted on this thread. Thumbs Up Current:
2014 MY14.5 Range Rover Sport SDV6 HSE - Santorini Black
Post #430294 Sun Jul 13 2014 7:11am
philmw
United Kingdom 2012 Range Rover Sport Supercharged Sumatra Black
I noticed the other day the black coating on my MY12 calipers is chipping off too, so not a new problem.
Post #430307 Sun Jul 13 2014 9:21am
andman
Any updates on the brakes caliper paint quality
Slim.. how have your replacements held up..
Gavin B ... Jim4244... you both had issues.... have they been resolved
or are LR still using the old bin of poorly sprayed parts 2014.5 SDV6 AB Dynamic ... Fuji /Santorini Pan roof and 22's
Post #432528 Thu Aug 07 2014 6:48am
slim_sane
The replacement ones I have have been holding out the peeling, however I'm still monitoring the situation and have a quality issue open with Landrover in regards to this, so they are on standby as both the dealer and I are pretty sure it's going to happen again it's just a question of when. However, credit where credit is due Landrover have responded well to my pleas, Pete has also been keeping an eye on the issue so between the dealer and him I'm confident they'll sort something out should the same happen.
I wonder how Jim is getting on though as I remember he was having his replaced before me, so he might have some news. Jim?? Question Current:
Post #432529 Thu Aug 07 2014 7:00am
