![]() | Home > Technical > code p132b tdv6 |
gazzc Member Since: 07 Jan 2010 Location: cheshire Posts: 494 ![]() ![]() |
anyone |
According to the OBD codes app on my tablet that code is a Ford code; Turbocharger/Supercharger boost control "A" performance
Possibly padding but when engine was out I freed it all off and fitted a new actuator kit. .everything seemed a1 but started it up and this happened |
Sorry meant to say Paddi not padding. Fat thumbs |
Just wondering if during the rebuild you could actually see the variable vanes. I've seen some videos of a turbo being dismantled for cleaning and the vanes mechanism was totally clogged with half an inch of sticky black goo. There is a product from Innotec for cleaning the turbo but it has to come off so not a simple job! 2008 MY Java Black TDV8 HSE
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9097 ![]() ![]() ![]() |
With the black smoke and being down on grunt, I'm wondering if it's something more simple such as a split turbo hose or even a damaged intercooler. 2012 SDV6 - it's missing a couple of cylinders
yes we could see the vanes and everything was freed off and a new actuator bar was fitted and working freely,i have checked hoses,i suppose it could be a faulty intercooler but i would think it would make a noise when i hoofed car,thanks for help any more ideas would be great |
when i say i fitted a new actuator i actually meant the actuator bar |
i think its the actuator on my turbo causing the fault ,can it be changed without removing shell,i have removed heat shields and arch liner and i think i can see it,is it possible |
