![]() | Home > General > weights on rear |
cossiedave Member Since: 20 Jun 2012 Location: lancaster Posts: 882 ![]() ![]() ![]() |
I have just found 2 big weights either side off rear exhausts. What are they for and can they be removed |
JPR 1 Member Since: 29 Jan 2013 Location: Cheshire Posts: 435 ![]() ![]() ![]() |
They are to reduce vibration |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 950 ![]() ![]() ![]() |
i was just about to ask that very same question... having just noticed these weights whilst poking about at the back end |
They're harmonic mass dampers. 2012 SDV6 - it's missing a couple of cylinders
Marsie Member Since: 20 Jul 2011 Location: sheffield Posts: 376 ![]() ![]() ![]() |
supposed to stop vibrations and car sickness apparently? |
B3EEE Member Since: 20 Apr 2012 Location: Wales Posts: 450 ![]() ![]() ![]() |
I've had mine removed. Some say they are there for a good reason, but vibration/sound dampening seams a bit of a silly idea, especially since mine were rubbing on the HST rear bumper ! Not noticed a single difference, except I don't hear the knocking noise anymore ! |
cheers b3eee i will remove them next week as they look like they weigh a fare bit |
SVR575 Member Since: 16 Apr 2008 Location: uk & Europe Posts: 1827 ![]() ![]() |
took both of mine off and i now get an extra 5mpg! |
You want to see the size of the ones on the Fullfat, size of a bloody building block. If your gettin 5 mpg more, I'm bound to get more than that |
RRS Daz Member Since: 22 Jan 2012 Location: Yorkshire Posts: 797 ![]() |
5 mpg |
ShooterNeil Member Since: 14 Nov 2012 Location: Tamworth Posts: 422 ![]() ![]() ![]() |
How do they come off |
IIRC, the rear of the body needs to be lifted, as they are one piece and go over each chassis rail |
dover Member Since: 22 Dec 2013 Location: Waipu Northland NZ Posts: 15 ![]() ![]() ![]() |
I'am surprised you have had the weights removed with no problems , Rover I would think would have researched the gains for having them fitted 2012 RRS. Orkney Grey |
CUCO Member Since: 02 Jun 2011 Location: Spain & Oleee!!! Posts: 59 ![]() ![]() |
on a discovery 4 MY10, they have a nut that separate them in two, so, bumper off, loose the nut on the weights, loose the screw of the silent block, be careful with your feet (is a very heavy piece of iron!!) and you are done.
