![]() | Home > General (L494) > Height with boot open. |
chesterfield Member Since: 14 Jul 2011 Location: Chesterfield Posts: 123 ![]() ![]() ![]() |
RobF Member Since: 11 Oct 2013 Location: Suffolk Posts: 56 ![]() ![]() |
If I understand the question right, then yes! Mine is 2130mm at the highest point. |
Excellent, thanks Rob. Though just got the final quotes back on the extension build, and it may be cheaper to just move house! |
6.5m in length, I worked on the possibility of getting Phantom in there at some point in the future, but then realised that should I be in a position to have one of those, I would have moved house by then. So I now have room for a nice workbench instead.
andman Member Since: 08 Oct 2011 Location: la vella Posts: 1155 ![]() ![]() ![]() |
Nearly come a cropper with that hydraulic boot on my old MY12 so many times....
philmw Member Since: 18 Aug 2006 Location: Nottingham Posts: 1678 ![]() ![]() ![]() |
One thing that should be done is a connection between the rear parking sensors and the boot opener, so you can't press the button and open the boot into a brick wall.
I did once press the boot button accidentally while travelling at speed... and the boot didnīt open... so there must be a speed related sensor... 2014.5 SDV6 AB Dynamic ... Fuji /Santorini Pan roof and 22's
If it does hit an object or similar, it does stop and reverse, but I'm not sure how much pressure it exerts before doing its thing. My main concern is a towbar mounted bike rack and accidentally pressing the button |
matsoutback Member Since: 13 Jul 2016 Location: Queensland Posts: 152 ![]() ![]() |
Old thread, but close to my query... Can anyone tell me how much space you need behind your RRS to open the tailgate without it hitting the garage door? I'm paranoid the first time I park in my garage (6.5m deep) I'll hit the button, then bang...
If you have a reversing cam then one of the sets of colour warnings is when you pass the point where you can no longer open the boot safely without hitting what is behind the car. So if you drive into the garage and close the door then keeping your foot on the brake engage reverse the cam will let you know if you have enough clearance to open the boot. IIRC it is in the instruction manual that no sane man will ever read............ 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
donny dog Member Since: 23 Nov 2016 Location: yorkshire Posts: 772 ![]() ![]() |
Don't forget that, if you have an up-and-over door, you need to be sure that the tailgate won't open underneath the door rather than in the free space beyond the door, especially as you will be likely to want the garage door open at the same time as accessing your boot. (If you have a power operated up-and-over door, the same applies even with the door closed). |
Thanks Tim and "Dog"
Mat, the surround camera is great! Well worth it for a car this size. You get an aerial view of the car which exactly shows your surroundings as well as the ability to look closely at any view you want, for example the wheels/kerb area when parking.
That's reassuring, thanks for that. 2017 MY17 SDV6 SE |
